Discuss Best/ most useful charge points on the market in the Electric Vehicles Advice Forum area at ElectriciansForums.net
I got a phone call from him last night… he’s drove up to his lodge in aviemore….
“If we get a double charger for the house… can you put another one up here?”
So the next question is, do any of these work without full internet access?
I can put in a hub without the internet access so that we can still link the charge point with a phone?
The lodge has its own electric supply, at least a 60A fuse…. Not off the sites installation.
I believe zappi doesn't actually require Internet access
Yes the zappi con work without internet, it does use it for updates to software though.
If you only have a 60a supply then I would use a harvi to control the two points so they don't end up using all the supply capacity. Although you can set a maximum current limit in the charger to stop them taking the cut out fuse out if both get used together!
This is what i was wondering....
CT clamps will keep them from pulling too much, but with a dual unit... (2 cars plugged in at once into the same unit) Can one be set as priority, and the second one kick in when the first is at 90% or whatever.... or say, charge car 1 for 6 hours, then car 2 for 2 hours. ???
Might not be so easy with 2 x individual units
I've not seen a twin zappi 7kw version, not sure if such a thing exists yet! But yes CT clamps will do that, you probably can master one of the points, not sure exactly how as there are so many options within the menus.
@Gavin John Hyde would be a good shout he is into his EV and has probably had experience with a lot more manufacturers than I have.
Reply to Best/ most useful charge points on the market in the Electric Vehicles Advice Forum area at ElectriciansForums.net
I was at my shed this morning, and something came to my mind about installing a charge point and taking payments for charging cars. I say “shed”...
Hi, I have a 6kw PV with a 6kw Growatt battery and invertor. I have a solar iboost going to the hotwater tank. Recently I had a Ohme Home Pro...
Hello all, To avoid too techy questions, i am the consumer not he installer. I have raised the issue with my installer who is researching it...
So I am a fully qualified spark with my own company, however I also have a few properties I rent out. One of my tenants asked if they can have an...
11K
Afternoon all, and apologies if this has been covered elsewhere, but a search didn't bring anything up. Just a quick heads up to anyone...
