Like Davesparks, I've no idea why you would want to put a strap clamp onto a bolt, as the bolt and lug is a standard way of making a sound heavy connection for any purpose. I would simply crimp on a lug and bolt it to the structure, suitably treated to prevent corrosion etc. But your comment raises an interesting point.
When two smooth metal surfaces appear to be in contact under moderate pressure, due to microscopic roughness and contamination only tiny high-spots (asperities) actually make metallic contact that will pass current. These total a very small fraction, sometimes as little as one millionth, of the apparent surface area. As the pressure is increased, more and more of these asperities are crushed and spread out, increasing their area and allowing lower spots to start making contact too. Pressure = force / area, so when you have a certain maximum clamping force available e.g. from a particular size of screw tightened as hard as it will stand, within limits you will get better and more reliable contact with smaller area and it will be more gas-tight and corrosion resistant.
The best contact that a strap clamp makes with a pipe is mainly where the pips on the saddle touch, the rest of the clamp merely holding it in place and providing backup contact. I would expect as low or lower contact resistance on the thread compared to a smooth pipe of the same material, as the bits that dig in will dig in at least as well. I'd agree that it's a bad idea to clamp a thread, however, because the long thin line of (good) contact is very exposed to the atmosphere by the groove of the thread and prone to corrosion.
