. biggest your really get is something like this single phase Wylex NMDISS119 Consumer Unit 20 Way Dual RCD + Switch - http://www.gil-lec.co.uk/wylex-nmdiss119-wylex-consumer-unit-20-way-dual-rcd-switchThis might sound silly, you say no light fittings etc are in the price, so if customer does not come up with the fittings or can't make their mind up.You will have to provide pendants etc at the very least.? IMO I would price for that if it's needed.
Another option if it helps at all. Hager do a similar board but it's a mamouth 20+20. Design 30 metal clad etcYeah I price per point and use the above formula to double check myself. biggest your really get is something like this single phase Wylex NMDISS119 Consumer Unit 20 Way Dual RCD + Switch - http://www.gil-lec.co.uk/wylex-nmdiss119-wylex-consumer-unit-20-way-dual-rcd-switch
Is that dual RCD on each row or just a main switch board?Another option if it helps at all. Hager do a similar board but it's a mamouth 20+20. Design 30 metal clad etc
