Discuss Blowing breaker in the DIY Electrical Advice area at ElectriciansForums.net
Cmuehling
I have a very small circuit in my house. Probably 8 outlets 6 lights. The breaker for this circuit has a direct short somewhere. It didn't start this way. At first it would stay energized for a couple of minutes then trip. The more I reset it the shorter it would last. Now it trips immediately. I can sometimes see an arc when I reset it. I have replaced the breaker, I have removed three of the light fixtures and pulled out 6 of the outlets from the wall to inspect them. I removed one of the outlets. Besides removing all of the fixtures what is the best way to troubleshoot the problem. I should mention that most of the light fixtures have 2 or 3 way switches.
The fact that you have been repeatedly closing the breaker when there's a fault condition means it is probably now in need of replacement. You will need an electrician to do some testing to see what the original al fault is.
Reply to Blowing breaker in the DIY Electrical Advice area at ElectriciansForums.net
We have one room that seems to have lost most of its power last night. One of the outlets in the rooms has a power strip plugged in that powers...
Summary (TL;DR) Several lightbulbs in my home supplied by one circuit breaker dim over time and go out in about a year. Right now, the ceiling...
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
