Moving consumer unit for first floor flat from a basement shop to locally within the flat itself via metal clad switch fuse at main intake.
Had a quick look around at condition of the flats installation beforehand. Moved / upgraded con unit and was happily carrying out testing. Moved into bathroom and the boiler is smack bang at the end of the bath and is easily within reach of anyone using the bath. The electrical supply / isolators are all behind a tiled boxing.
This is the only thing wrong with the installation.
Any advice on whether I could just write this issue in the comments and issue the installation certificate.
Or
Not reconnect the circuit ( boiler fed from the only ring main in flat) and tell client that the boiler has to be moved and all associated electrics in order for me to reconnect the circuit.
The flat has tenants with children so hard to leave them without power and hot water.
Any advice would be appreciated
Or
