- Reaction score
- 88
I need to wire a new system boiler, the obvious place to put the supply is with the control unit which powers the boiler. But should the FCU be next to the boiler in the same way any isolation switch would be located close the load. This would still power control unit, but also need cable coming back to boiler which would not be ideal. But then you could argue FCU is no longer local to pump/valves etc.
I can't see anything in OSG about this?
