Feb 23, 2020
117
159
118
London
Is there a cpc in the conduit?
can a metal box be used instead of the plastic? Should come in the same sizes (standard one gang?)
Does it need earthing across the switch. Assuming the incoming conduit is earthed a separate cpc through the switch can pick up the outgoing conduit further along at an accessory.
If you have to use a plastic box for the timer I'd run the steel conduits into a galv adaptable box and bush the plastic box into the side of it.
Reactions: Dave OCD
I agree this is the best method. Unfortunately, I've already hit the knockouts but lesson learnt.
London
Bonding steel conduit around plastic switch
JosephandAmber,
JosephandAmber,
