Discuss breaking capacity of overcurrent devices in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
hit me down with a sock ,you live and learn .didn't know there was a table, thought you just measure PSCC and make sure that the breaker capacity is greater
Try table 7.2.7(i) on page 79 osg
thats not fair, I'm now going to hide up in attic now .7.2.7(i) OSG page 79
don't chew the cables.thats not fair, I'm now going to hide up in attic now .
types of wiring usually bottom of schedule of test forms. and earth bonding is not 0.05 ohms. that's a myth. the 0.05ohms refers to the resistance between a bonding conductor and the pipe its bonded to ( i.e. across the bonding clamp)Thanks very much guys also quick question where do I find codes for types of wiring? I have found the codes for installation methods
Another pick of the brains I know earth bonding should be less than 0.05 ohms but where in the regs/osg does it state that?
I’m wondering if someone can tell me in the OSG or regs that it has the short circuit breaking capacity of overcurrent devices someone said it was table 7.2A but can’t find it anywhere
proteus 3871 MCBs, am i right in thinking 3kA?
Reply to breaking capacity of overcurrent devices in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
