Discuss Broken CPC on Lighting Circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
First time posting so hope this is correct place? Been checking out a Customers Premises and all is good apart from 1 lighting circuit that feeds a bedroom and office. A CPC has been run but has been damaged/broken/cut somewhere en route to first light switch. (proved by using wander lead). Subsequent CPC to next switch shows good continuity. Be interested to know peoples thoughts?
1. All fixings are plastic so ok to leave? - Although i know this is not an option I'm sure
2. Try and get a new feed from other lighting circuit?
3. Other options that people have done in same situation?
Cheers
Welcome to the forum mate.
IMO option 1 is not an option. If people see an earth to a switch they will think functional and it's suitable to change the switch to a class 1.
I'd fix it.
1. No, it doesn't comply.
2. No, why would you combine this circuit into another lighting circuit.
3. Find the fault and fix it, or replace the cable with the fault.
What's wrong with extending the end of another existing lighting circuit to join this one with a new LNE ?
This would be easier for a new cable run back to the CU. The old cable would then be disconnected.
I thought the broke CPC was 'en route to first light switch' as in your first post?
Isn't this just a switched live or is it wired up different?
Broken CPC is "en route to first light switch" but it is looped at the Switch, therefore feed from CU starts at this switch. My plan would be to sack of this cable completely and run a new feed from an existing Lighting loop.
I guess just like would you'd do if you are adding extra lights to an existing circuit.
Can't you take the cpc from another point on the same lighting circuit?
first check that the end of the cpc has not broken in the CU. common problem with 1.0mm.
The thing is, if you don't know what has caused the fault, then you don't know what other damage there may be to that section of cable.
I have no CPC from CU to first lighting loop Switch. That's my problem
Ok, so as @DPG stated above, surely you need to replace the cable from the CU? or am I not understanding it correctly...
Maybe I'm not explaining very well, apologies.
Yes I need to get a good Line, Neutral and CPC to replace broken cable and the way I see it I can achieve this in 2 ways.
1. New Cable from the CU
2. New Cable from the Loop out from an existing Lighting Circuit.
Does this make sense?
Someone will have designed this installation with the number of circuits it has, to then reduce the number of circuits by joining them together seems like a bad idea.
Without seeing the installation and understanding what is on each circuit and why it's very hard to offer any other advice than to repair or replace the damaged cable.
Reply to Broken CPC on Lighting Circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
I've tried to research and form a plan without asking on here, but I'm just going around in circles. Just completed an EICR. The wiring ranges...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
I'm getting an old fuse board upgraded in an office block. The electrician has just told me that most of the circuits don't have earth cables...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
