Discuss Builders Supply in the Australia area at ElectriciansForums.net
cbw
Quick question,
I have recently started filling in a minor works certificate and notiffying a CU change for this.
Am I being OTT?
I have allways done a Ze then a Zs at socket and RCD test, then normally write the results on the wall!, just not really sure of the best course of action!
CBW
Builders temp supplies , I always do full eic , install PDU fed from DNO TT supply via rcd discriminated for PDU supply
Same as me, except I am talking minor scale, 1 house rather than full building site, garage style CU and a couple of sockets, I just dont do the full EIC, would you notify???
You are already more conscientious than most mate.....filling in any sort of form for a temp install is more than a lot of guys do I'm sure.
As Bugsy said file it with the foreman....happy days.:)
Reply to Builders Supply in the Australia area at ElectriciansForums.net
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Hi all, first post so go easy! This is for people who are looking for more info on the course and exams and is from my experience of doing the...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
I've just finished an installation on a large outhouse around 50 meters from the main property, but I'm having issues with unusually high Zs...
4K
