Discuss Cable needed to connect RCD to the DP main switch & neutral bar. in the Australia area at ElectriciansForums.net
Goody
Hi,
Trying to add an RCD to a wylex board that never had one. My issue is to get hold of those flexi cables that connect it to the DP main switch and the neutral bar. I have managed to get a set for a twin RCD board but does anyone know where to buy them in required lengths individually?
Thanks!
You could always use twin & earth!!
< waits for critical comment >
What, like thats a bad thing to use inside a domestic consumer unit! Ha!
If it never had one, then you must be putting the RCD as the main switch? Or do you have 2 neutral bars?
If you do the 16mm tri rated is what I normally use.
its probable that your old board hasnt got 2 neutral bars neither, by the time you have got an rcd and sourced the tails in question it would be much less hassle just to buy a split load board as a whole
yep....more time than its worth faffing about here.....and the old c/u can be used for a temporary power supply....or for a garage......
Reply to Cable needed to connect RCD to the DP main switch & neutral bar. in the Australia area at ElectriciansForums.net
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
Don't come across this very often - but I've had a CU delivered for a caravan job (not static btw), and it's been supplied with a neutral...
