Discuss can anyone id these lights. in the Lighting Forum area at ElectriciansForums.net
yes they are g4's they don't seem to want to come out of the ceiling when he pulls on the square fitting. that's why i wanted to id the make. I'm going on Monday so I wanted some idea of what I'm dealing with.
They look like this kind of thing:
Mini Downlights - Low Voltage - https://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Lighting_Downlights_Index/Mini_Downlights/index.html
It could be that they are held up by spring clips which hold down onto the plasterboard and they come out if you pull them hard enough, or they could be held in by springs on the side which wedge the fitting into the plasterboard.
This is all assuming the clips haven't broken off and been lost, and the fittings superglued onto the ceiling.
I would expect them to fit to the board in the same way they would fit to a plastered ceiling.
You could maybe take one of the boards down and have a look?
if no dimmer involved replace the halogens with LED G4 bulbs, nothing will melt anymore and they will last much longer.
Reply to can anyone id these lights. in the Lighting Forum area at ElectriciansForums.net
Hi, asking for a friend in Australia. She wants to install two Pendant lights over a kitchen island and four downlights all on the same switch...
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
So I’m an apprentice and only get to do downlighter jobs as foreigners at the weekend, but they’re typically added when the customer no longer...
Hi guys Completed an EICR yesterday. One of the Sockets Radials had no CPC so R1+R2 plus Zs could not be not be completed. Does anyone know the...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
