djwhite
Hi, is there any one who can advise me if I can have a USA light fitting(110V) fitted in the UK and just use a UK light bulb that fits the bulb fitting or would the whole thing need rewiring? Appreciate advice
Depends if it is a straight forward light fitting without any lamp control gear or not!! If it has anything more than a lamp holder, then no you won't be able to use it without modification....
Hi, I would not say this is a cheap one, I paid around $500. It is not really fancy, just quite large which is what I needed. We have a very high ceiling in a new room we built and I wanted a large light fitting. The US market caters for larger size rooms Vs what you can buy here in the same price range. It has standard type wiring and no control gear to the lamp, just standard screw bulb fitting. I have check a buld here and the standard ES bulb fits it.
I wouldn't have a problem using this light fitting in the UK. The internal wiring size and it's insulation voltage rating will be fine too....
The Edison Screw lamps are a standard size pretty much worldwide...
I'm on the understanding that there's only a slight difference in the European and US ES holders, about 1mm. To be 100% I would change the holders for European ones as that little bit of play could cause overheating. If it's single phase wiring I can't see there being many problems but I would be confirming the cable type and rating to be on the safe side.
If there is a difference i've never noticed it before. On most of the projects i've been on, our ES light fittings and lamps come from several different countries, can't say i noticed any noticeable play from one fitting to another with whatever lamp was used. Not saying your wrong, just that i haven't seen any difference between Yank and European ES lamp holders and lamps... American Wire voltage ratings on LV have an absolute min of 300V, but more often than not will be higher. It will also be 90/120C rated in such a light fitting too...
Can I use USA light fittings in the UK
djwhite,
Engineer54,
