Discuss Can someone help me fix an issue with my doorbell? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ok so I tried to replace my door bell, but when I took it out the wires were twisted and snapped off too short to rewire. I’m a trainee electrician with little to no experience so I’m stuck.
Can I get some more wire and try to extend it by wrapping it around the old wire and covering it with insulation or Is thst too dangerous.
I have no experience or real no know how in replacing the whole wire but is that the safest option?
- I did try a chockblock but it didn’t work because it doesn’t fit into the hole with the existing wires.
TL;DR
first need to know 2 things....
1. what voltage is used there, hope it's not 240V.
2. can you get to the cable on the inside of the wall and pull it back through?
You could do away with the cables and fit a wireless bell, whereby you fit a transmitter at the bell push site and the sounder is a plug in unit which you can take from room to room stops you missing the bell if you are upstairs and can't hear thr normal sounder, I have one and its brill.
@JayLynch712 - If you're in training; jump in the Trainees Section of EF, it might help with your progression
Reply to Can someone help me fix an issue with my doorbell? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Hello. I am located in the Maryland, USA and have no real electrical experience. I just replaced my Nest video door bell with another...
5K
