Hello Dustydazzler.No back box what so ever ? just a hole chopped into a unit I have seen this done a few times where space is super tight but not a big fan of this method personally
kind of reminds me of older 1950s houses wired in splt tube where the switch boxes consisted of 2 tiny bits of wood set in a hole to screw the switches on the wall
Hello Snowhead.What is it fitted into, a kitchen unit or?
Can you easilly access the back of the switch?
Hello Risteard.No it isn't okay not to have a back box. Nor is it okay to use a green/yellow conductor as a phase conductor.
No it was a proper electrician, I was surprised but trusted in his knowledge as he was the electrician. With hindsight I should have challenged him. I did mention to him that I would be confused with a earth sleeved cable going to a live connection, but it did not seem to bother him.So it was left like this because he didn't have a back box? And he's used an earth wire for a live? Was this a proper electrician that has done this or a kitchen fitter?
Hello Oscar 21.The back box is to prevent the spread of fire as well as stop anything toughing it, if there is a loose connection and it starts arcing it could set fire to the cupboard. This is what annoys me when boxes end up so far in the wall after its boarded, there ends up a massive gap between the socket and box up the back of the wall.
Used to be able to buy conversion brackets that fitted into hole, with an earth lug on the middle, chucked my last one away in the last 10 years. Stopped them not allowed anymore.No back box what so ever ? just a hole chopped into a unit I have seen this done a few times where space is super tight but not a big fan of this method personally
Hello 7029 DaveUsed to be able to buy conversion brackets that fitted into hole, with an earth lug on the middle, chucked my last one away in the last 10 years. Stopped them not allowed anymore.
