Discuss Central heating 2 gang box fitting in the UK Electrical Forum area at ElectriciansForums.net
B
brizospark
I require a central heating time clock that will fit onto a 2 gang metal box
Or is there a conversion kit that will allow me to fit standard one gang fitting onto 2 gang?
Thanks in advance
Not sure of one that fits on a double box, but you could look at the larger clock to cover off the top of my head something like a potterton mini minder e or something like that.
Reply to Central heating 2 gang box fitting in the UK Electrical Forum area at ElectriciansForums.net
I have two supplies into a new horstman e7 box, 1 from the offpeak water heating one from standard tariff boost do both suppies go to 1 and 2, 4...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
This is confusing, I've ordered a few bits of this stuff, some switch modules and front plates and in the bumf on the website it says:- Click...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
Hello everyone, We had an electrician over, who fitted a 40a MCB in the house consumer unit to supply a new build garage. It's underground SWA...
