Asked to remove a couple of storage heaters and replace with a socket outlet.
No RCD CU in place but obviously can fit RCD socket outlet, but I will have to extend cables in off-peak CU to 'on-peak' CU. I don't believe I need to RCD protect the circuit because the new cable I'm installing between CU is not concealed, even though I'm using the existing cable from off-peak CU to outlet point which is concealed.
Anyone disagree?
Anyone disagree?
