Confused. Most of the sockets in the house and light switches have cables in walls , although directly up from floor or down from loft...so what’s the difference ?
Someone suggested loft which I didn’t think about, although additional socket is on an external wall and original spurred from in on an internal wall.
I’m going to try and raise the original socket so it’s off the skirting and in-line with where I want to put the spurred socket. Will then run cable in wall in conduit directly across (2m), round internal corner and then directly across to (2m) to new socket. Will wire it in, make good and then get electrician to test it when the RCD protected CU goes in later this month.
