C
Chrishands
Hi somebody has asked me to do a job in a commercial premises. Can I legally do so without part p competent persons registration. Based on my quals . 2356 level 2+3. Test insp. Wiring regs. Thanks
Hi the work isPart P is for "Domestic Dwellings" so your answer is yes.
What type of work are you doing?
Hi the work is
"Jan 2013
*Re: comercial premises can i work
^^^ If that is a link, it does not work. PM me if you need help with that.
Also what would you quote labour to run a new circuit. 40A shower circuit. 16m long. DB in the same room. Surface trunking in a salon"
Thanks Ruston it has been a while since I had to worry about Part p***
I know a shower will be in a special location, but isn't adding a new circuit, even if it was in a hallway say Part P notifiable or have they changed that
any new circuit is notifiable under part pee. if the shower is above a sink for hair washing, then it's not a special location. however, RA needs to be done regarding wet hands etc.
perhaps i phrased that badly. what i meant was that you should assess any risks and reduce them to a minimum. earthing and bonding being a major factor. RCD protection as well.
Makes sense now! Where do you stand with Public liability insurance, is this still a necessity in commercial and industrial applications or does the public liability of the premises owner apply? Also What validity do your test certs have with their insurers. Thanks
