I was under the impression that swiming pools needed rcd or rcbo protection on all circuits that serve that location or pass through it. Its a commercial pool
But where I am the pool is feed with rcbos from one board but the board that serves the pool underwater lights pool heater and pumps has no rcbo is that correct?
I have seen the previous fixed wire test and it does not even list the board that supplies the pump under water lights and or heater
What supplies this board? There may be an rcd upstream, or there may be a board fed from this with rcd’s then feeding the lights.
thinking the lights are single phase, these are 3 pole mcbs
Board supplied from the main intake i think?
So all the lighting on the room is feed from rcbo
Its just the lights in the pool and the pool heaters and pumps that are not
london
United Kingdom
Commercial swimimg pool pir
dokkan1080,
westward10,
