DavidUK
Hi all, hope this is the correct section...?
We're buying a bungalow shortly and intend to do some alterations. One of those converts the utility room (photo below) into a bathroom. In the photo the consumer unit is in a short passageway to a larder. The door at the back will be replaced by a solid wall and so the consumer unit will be surrounded on three sides by solid walls at that point...
Two questions:
1/ If I put an internal door, door frame, and fill in the wall above, on the open side of this so as to create a "room" approx. 1m square, would this alone satisfy electrical regs? If not, what else would I need to ensure is done?
2/ If I demolish the right hand wall and the wall behind the fridge (behind which is a single WC/cloaks) and the consumer unit is then fully exposed in the new bathroom, is there any sort of enclosure that can isolate the CU, i.e. a type of box/cupboard fitted over it?
Many thanks for any help.
Two questions:
