Hi, we have been asked to relocate a consumer unit however the meter cupboard will be on an outside wall 7m away from the consumer unit, the main switch is under 80amp, im just wanting some opinions on the way to overcome this, am I right in thinking I could run 16mm swa from the consumer unit, cleated to an outside wall, running to an adaptable weatherproof box situated next to the meter cupboard, then using Henley connector blocks, i could connect the swa to the tails coming from the meter box.
That makes things a lot easier then..
What is going where the old cu is located?
Can the isolator go there?
Its a temporary thing at the moment, the meter is being moved friday but for now until a few months down the line the cu is staying where it is, then eventually it will moved behind the meter cupboard, so really for now I need to connect the exsisting cu to the new mrter cupboard
The meter boxes have knockouts in the bottom that can be reinstated later on..
I would come out of the bottom in trunking and then go bottom entry into an enclosure with the isolator inside.
We’re supposed to use designated entry points in the meter boxes
South wales
Consumer unit replacement
Mikey10695,
Charlie_,
