A
amberleaf
Electric Shock : FaultProtection
The term “ Fault Protection “ is used in BS-7671:2008 .to refer to protection of persons & livestock against Electric Shock as aresult of making contact with Exposed-conductive-parts that have become LiveUnder Fault Conditions . ( mainly with regard to failure of basic insulation )
Definitions – p/24. FaultProtection : Protection against electric shock UnderSingle-Fault Conditions .
• Preventing a current resulting from a fault frompassing through the body of any person
• Limiting the current which can pass through the bodyto a Non- hazardous value .
• Limiting the duration of a current resulting from aFault which can pass through the body to a Non- hazardous time period .
Regulation . 131.2.2. ( goes onto Confirm that )
In connection with Faultprotection . The application of the method of ProtectiveEquipotential Bonding is one of the ImportantPrinciples of Safety . ◄◄
:thinking2:
SP&N . single-pole & neutral .
TP&N . triple-pole & neutral .
:thinking2:
we can use this method because we are using separate factors for Insulation .
