A
amberleaf
O.S.G.. The use of other methods’ of determining Maximum Demand is Not Precludedwhere Specified by the Installation Designer
FirstlyI make no Apologies for the Way am Writing on any Matters . it can be a first day Apprentice or some one Needing aJog of Memory .
Sowe are all in the Same Boat . “ To Learn “
For the Apprentices . The Day we stop learning is the Day we hang Upour Tool-Bag
CookerDesign Current Calculations
Thefirst thing you have to do is get Your Head around the Calculations !!
(From a Design point of View ) 2392-10
DomesticInstallation Oven(s) & Hob(s) are to be Calculated upon their MAXIMUM LOADING
Startwith a simple Calculation ( An Oven has a rating of 2kW ) 2000
(I = P/V ) Formula … I = 2000 ÷ 230V = 8.70A …. Weare Using the Unit Amps
2392-10/ Domestic Installation Oven(s)
Ovenhas 4 Rings ( 2 x 1kW ) & ( 2 x 1.5kW ) & Grill ( 2kW ) & Oven (3kW )
-Controlled via a CookerSwitch with a Socket outlet .
Asa Designer . we’ll have to Apply Diversity ??
Important )- Diversity allowance to be Applied to the FULL LOAD CURRENT for CookingAppliances .
TheO.S.G. is telling us . Purpose of the Final Circuit fed from theConductors )
O.S.G.Table 1B p/97 – column (3) Cooking Appliances → At the Top of the Page Note : Type ofPremises ( 2392-10 → Household Installations ) Domestic Installation(s)
DomesticInstallation(s) Only O.S.G. - 10A + 30% f.l – Full Load ) of connected Cooking Appliances in the Excess of 10A+ 5A if a socket-outlet is incorporated in the Control Unit . ( C.C.U. ) – 45A + 13A Socket Switched with Neon .
Fromyour point of View ( The First 10A ofthe rated current plus 30% of the reminder ( Plus) 5A if the Control Unit incorporates s Socket.
Calculations)- You bank “ Hold OFF“ the first 10 Amps of the Maximum Load Current )
The10A will be used at the End of the Calculations’
-So your Work out the Total Power Rating & then calculate the Full Load Current
Calculations)- Power = ( 2 x 1 ) + ( 2 x 1.5 ) + ( 2+ 3 ) = 10kW
I= 10000 ÷ 230V = 43.48A … round it up to the first four numbers43.47826087 ( 48 ) 43.48A
UsingDiversity allowance stated ↑↑ ( 43.48A sub 10A = 33.48A )
I= 33.48 x 30 ÷ 100 = 10.04A
Youradding the ( 5A ) for Socket outlet . I = 10A + 10.04 + 5A = 25.04A )- Asa Designer this is your Expected Current Demand .
Remember )- Supply Cables Rated to suit DesignCurrent ( Iz ) :)
Useful Junk .
Cable Reference :
CC – Bare copper sheathed .
MI - Cable .
V – PVC covered .
M – Low smoke & fume . ( LSF ) materialcovered .
L – Light duty ( 500V )
H – Heavy duty ( 750V )
Hence– a two-core 2.5mm[SUP]2 [/SUP] light duty ( MI ) cable with PVC oversheath would be ?? ( CCV –2L . 2.5 ) Next time look at your Pyro Cuter Tool ??
MineralInsulated copper sheathed ( MICS ) Cable . “ Fire Alarms“ :66:
UsefulJunk .
RingFinal Circuit : OneSolution . :aureola:
i)To indentify breaks in the Ring FinalCircuit & Interconnections across the Ring .
ii)Test with a Low Reading Ohmmeter between each ( L . N . & E . Leg ) &the corresponding terminal at the nearest socket .
- A Low value indicates the short leg .
- A High vale the Long Leg .
Reading at Mid-Point = 30m of 2.5mm[SUP]2[/SUP]+ 30m of 1.5mm[SUP]2 [/SUP]--- 2
=30 x 0.00741 + 30 x 0.0121 ÷ 2 = 0.293Ω
[ 30x 0.00741 + 30 x 0.0121 = 0.5853 )- ÷ 2= 0.293Ω ]
ThisValue is ( R1 + R2) Ring Final Circuit .
30m/ half of - 15m
UsefulJunk .
MainIsolation . 100A
TheMain Intake position . Domestic Installation . Usually as part of the ConsumerUnit . 2392-10 (- The means to Isolate the Supply to whole Installation .
Thereis a requirement to Ensure that such Isolation beAccessible :aureola:
Tomany times I,e seen them under Stairs incupboards’ . Etc
►Part P – ( BR ) 2006 p/134 – Note/ 3 :19:
Garages
Are considered to be Unsuitable for standard main frequencyfluorescent fittings due to ( ► Stroboscope Effects ◄ ) with rotating equipment .
[ Fluorescentlamp with ( High frequency electronic ballastsubstantially reduce this RISK . ]
Inductive Loads .
Motors: Discharge lighting – Metal halide : Fluorescent or Neon:beatnik:
PartP /Building Regulation – p/15 – look in Chapter 10. 117 :19:
►The ABC,s of the BuildingRegulation . ( BR)
Part ( A ) “ Structure“ Where the positioning of ( Holes in a Joist ) Depths of chases in a masonry wallare affected .
Part( B ) “ Fire Safety “ Considers ( Smoke Alarm Systems ) & what must be done tomaintain any ( Fire Barriers ) That have been ( Breached during Work ) in a Dwelling .
Part( C ) “ Résistance to Passage of Moisture “ Looks at the ( Ingress of Moisture ) through a wall & therequirement to limit moisture build up .
Part( E ) “Résistance to Passage of Sound “ Oftenoverlooked when fitting equipment in ( Ceilings &Walls ) The sound barrier is to be maintained .
Part( F ) “ Ventilation “ Requirements for fitting of Ventilation in certain roomswithin a dwelling & the required amount of ( AirFlow ) -&-s. Big / Time
Part( L ) - ( L1A & L1B ) “ Conservation of Fuel & Power . This covers both ►New& Existing dwellings ◄ for fitting orrecommending a certain amount of ( Low-energy light fixtures )
L1A / ► New Dwellings . L1B / ► Existing Dwellings .
Part( P ) – Electrical Safety ( P1 )
“Access to & use of Buildings “ Heights of Switches . Socket outlets &other equipment .
p/133. Part ( L ) – Fixed Internal Lighting . -&-s .
One energy efficientlight fitting per four ( Fixed light fittings ) read Note[SUP]2[/SUP][SUP] [/SUP] below . Whichever is the Greater .
►one per 25m[SUP]2[/SUP] of floor area ( excluding garages ) Note[SUP]2 [/SUP]&Note[SUP]3 [/SUP]. Whichever isthe Greater .
Note[SUP]1 [/SUP].Note[SUP]2 [/SUP]. Note[SUP]3[/SUP]. p/134
Rectification . in Wording . :43:
p/15- Building & Structures . with regards to SocketHeight as ( Part M ) sorry not Part P . Small Overpart on mySide .
TwoPart’s - Part / P . ( P1) “ Meaning “ Electrical Safety ( Firstly )
Part/ M . Heights of Switches. p.137 / 450mm . 1200mm
Kitchen Installation (- p/61
Rememberthat . in the ( BR) Kitchen is defined in the Building Regulations . as a room or part of a room ( -&- ) Specialinstallations . Special locations& Kitchens . p/59
( Not in Regulations BS-7671:2008 / Kitchen as Speciallocations )
To Overcome Thermal Insulation Issues . 17[SUP]th[/SUP]Edition 2008 .
:beatnik:
Isi t permissible to design a Ring Final Circuit using 2.5mm[SUP]2[/SUP]cable protected by a ( 20A ) protective device .
( Yes ) if the effective CurrentCarrying Capacityof the cable is at Least ( 12.5 amp –20A x 20/32 ) So as to effectively have the same “ Deemed to comply status “
As regulation(s) give to ( 30A & 32A Ring Final Circuits )
Useful Junk .
:19:
Youare Advised that it is ( Unlawful ) under the Electricity at Work Regulations 1989.
Towork on any Electrical Installation in the UK . unless you are a “ Competent Person “ ◄
TheElectricity at Work Regulations 1989 . requires persons to be Competent to prevent Danger& Injury . ( You will see this in the Regulations )
NoPerson should be Engaged in any work activity Unless . He or She possesses suchTechnical Knowledge or Experience . or is Supervised as appropriate for theWork .
TheMemorandum Qualifies Technical Knowledge or Experience as being .
i)Adequate knowledge or experience .
ii)Adequate experience of Electrical Work .
iii)Adequate Understanding of the system being worked on & practical experienceof that ( Class of System)
iv)Understanding of the Hazards that may arise during the work & thePrecautions . That . should be taken .
v)Ability to recognise at all times . whether it is Safe for Work to continue . Etc .
Useful Junk .
:19:
Copper isUsed for Underground Cabling in the transmission & Distribution Systems or (Where Weight is not an Issue ) right down toDomestic Supply ( Due to it’s LowResistivity )
Firstly am NOT a Tutor . Amber .
I can offer some Guidance Only.
Amonly using this as One Example . Can you be Asked this on 2391-10 . Exams?? ( A /B ) :willy_nilly:
Explainthe Terms : 2391-10
a)Main Earthing Terminal .
b)Main Protective Bonding Conductor .
c)Exposed – Conductive – Part .
a)Main Earthing Terminal . 17[SUP]th[/SUP] Edition . p/26
TheTerminal or Bar providedfor the connection of ( Protective Conductors )including Protective Bonding Conductors . &conductors for ( Functional Earthing ) if any .to the Means of Earthing .
b) Main Protective Bonding Conductor . 17[SUP]th[/SUP]Edition . p/32
Electrical Connection maintaining various ( Exposed Conductive Parts ) at Substantially the same Potential .
2391-10(- This involves joining together ( Metalwork )that is or may be Earthed so that it is atthe ( Same Potential) to prevent “ Danger “ Electrical Shock“ . frombetween those pieces of Metal as the Earth systemhandles a Fault .
c)Exposed Conductive Part : 17[SUP]th[/SUP] Edition. p/24
AConductive Part of equipment which can be Touched & which is NOT LIVE which can become Live when basicInsulation Fails .
17[SUP]th[/SUP]Edition . Conductive Part : of equipment which can be Touched & which is NOT LIVE which can become Live when basicInsulation Fails .
Refersto Items like :
TheMetallic Covers of electrical equipment which will normally be at Earth Potential . but which may develop a Voltage if the Fault Current goes through Equipment .
The following errors occurredwith your submission :willy_nilly:
The text that you have enteredis too long (17382 characters). Please shorten it to 10000 characters long.
The following errors occurredwith your submission :39:
Part1 ) “ This is some thing I knocked up Amber . “ Wording comes in different Meaning on Exams . But they all work aroundthe same principle(s)
Firstly)- What is ( Zs) in Definition . Earth Fault LoopImpedance . ( Ω ) 41.3 – Maximum Earth Fault Loop Impedance .
2392-10.
Q)- A Prospective Earth Fault Current Test.
needsto be carried out on a Domestic Installation .Which has a Type “ B “ circuit breaker fitted .
State ( Which instrument(s) can be used . The testvoltage & current supplied by the Meter.
Whatequipment is likely to be fitted to the circuit .
State( the precautions needed to be takenprior to the test .
Describethe Test .
i)State ( Which instrument(s) can be used. The test voltage & current supplied by the Meter.
AProspective Earth Fault Current Test .
( PFC Tester ) – or Loop ImpedanceTester : with function ?
Thevoltage range the meter will work on it from ( 50Vto 500V ) which is taken form the Supply it is Plugged into .
Workon is from ( 50 V ) to ( 500V ) Which istaken from the supply plugged into .
Itmeasures the current between Line & Neutral across an Internal Impedance inside theTester . ( PFC ) = I = V/R = 230 / 0.5 =460A )
Yourmeter . will return a Value . 0A up to 50kA . ( 2392-10 – Youwill not use this Method in Initial Verification )
Asthe regulations say . ! Values can also be ascertained by (Calculation or Measurement ) “ Meaning “ Determined by other ways . 612.11
Thisis a Live Test . You may be measuring Live Energised Conductors ( Whenusing Clip-on Leads ) when -&-s are looking for . ?? Safety at all Times .
Part2 ) Firstly : as Tester. 2391-10 & 2392-10. :39:
Secondly : Competent Person .
Competent Person . As this notthe first Live Test . ( PFC ) you WILL HAVE Informed persons . “ Meaning “
TheWhy’s . ►Warning Signs – Informing persons whocould be AFFECTED by “ LiveTesting “ ◄◄ This is what -&-s like to Hear .
What other Precautions Required. ?? Are you not the Person conducting the TEST. ◄◄ Yeah
1)Check the condition of the “ Test Instrument “& “ Probes / Leads
2)Check Test Leads & Probes conform to ( GN-38) ↔ full Title / HSE .
3)What –&-s . harp on about ?? Working with Live Terminals / Careful not to TOUCH any LIVE PARTS ( 17[SUP]th[/SUP]Edition 2008 )
MCB32A – BS-EN 60898
So. for the sake of the Regulations .
Youshould check your reading against the Time Current Graphs for relevant devicesto get an Actual Disconnection Time . 2391-10 ( 460A ) ?? 0.1 s / 5s
2392-10- You should check your Disconnection Time Table 41.1 ( TN-0.4 or TT-0.2 )
Example. ( PFC ) = I = V/R = 230 / 0.5 = 460A )
( 230V ÷ Ze / 0.28Ω= 821A )
( Ia ) /Operation of protective device within the time stated – Zs = Uo/Ia . 6A ÷ Current / 30A = 0.2s
TwoTests . Here . 612.11. ( PFC )
Prospective Short Circuit Current . …. Line & Neutral
Prospective Earth Fault Current . ….. Lineto Earth
Measurethe ( PFC ) at the Originof the Supply .
Etc. Check that the test instrument . Leads. Probes & Crocodile Clips . -&-s GN-38
►►►Check the Polarity Indictor ( if Any ) on the instrument for correct connection
Usingthe ( PFC ) Loop Tester set the selector switch to ( PFC ) & the range switch tothe highest setting ( test for PFC Value)
Youcan ( Reduce the Range switch to a Lower Setting ) to obtain a more AccurateValue .
Withthe . Megger 1552 / you have two settings . (PFC → No-Trip ) ( PFC → Loop– Hi )
Ifthe voltage measured at the time of test is 230V & the measured value ofFault Loop Impedance between Line & Neutral at the Originis ( 0.05Ω )
Maximumprospective Short – circuit = 230V / 0.05 = 4600A ( or 4.6 kA )
If( Ze ) is known & the Looptester does not have the facility to measure EarthFault Current .
Itcan also be Calculated by using the formula . ( Ipf ) = Uo / Ze .
p/35– Regulation . ( Ipf ) Prospective Fault Current .
p/36– Regulation . ( Uo ) Nominal Line to Earth voltage .
p/36– Regulation . (Ze ) External Earth Fault LoopImpedance .
3-Phase Installations the ( PFC ) recorded is Twice ( 2 x ) the Maximum SinglePhase Value Measured .
InsulationRésistance . in your own words . Example. :6:
Example- Table 61 (- SELV = 50V/ A.C . to 250V /D.C.. ( V ) to ( MΩ ) ≥ 0.5 . (Mains to D.C. Current ) Remember . MinimumInsulation Résistance “ Wording “ . ≥ 0.5 - MΩ .
RingFinal Circuit . Basics. :6:
Statethe effect on Conductor Résistance when Cables are Connected in Parallel .
Current in a Parallel Circuit.
Ohmslaw states that the Current is ( Inversely Proportionalto the Circuit Résistance ) Thisfact is True in Both ( Series ) & ( Parallel ) Circuits .
Thereis a Single Path for current in a ( Series )circuit .
Theamount of current is determined by the Total résistance of the circuit &the applied voltage . In a ( Parallel ) sourcecurrent divides among the Available Paths .
Apprentices. :39:
Revision– Factors affecting Résistance .
Therelationship between the length of a conductor & its résistance is said tobe ( - Directly Proportional. / to its Length ( L )
Therelationship between the Cross-sectional Area of a conductor & its résistanceis said to be ??? Proportional.
• Thicknessof a Conductor . “ Cable “ Wire “
The Cross – sectional area of a conductor ( Affectsthe Résistance ) Thicker Wire provides ( Low Résistance) because they have more space for Electrons tomove .
Fevercollisions occur .
(Smaller )- Wire of the same substance ( Provides HigherRésistance ) because they Offer Less Space for to move around in .
If you still get them in-&-s . How to remember . ( Proton is Positive ◄►You can remember that because they both start withthe Letter ( P )◄◄◄ Two / Ps
Proton = Positive . ( Two. P ) -&-s :6:
Neutrons= Neutral
Electrons= Negative .
Extra Low Voltage . p/31
AnyVoltage in a Domestic Installation UPTO ( 50V ) Thinkabout - SELVor PELV
SELV or PELV
ElectricalProduct may also be Indentified as a ( PELV ) - ProtectiveExtra – Low – Voltage . ( Low-Voltage but connectedto Earth ) watch this -&-s . :6:
SELV . Separated Extra – Low –Voltage. ( Low-Voltage but with Output Isolatedfrom the Input ) watchthis -&-s . :6:
Apprentices)- some Testing matter to think about . Numbers . Yeah . :willy_nilly:
( R1 + R2 ) Testing – method( 1 )
( R2 ) Test - method ( 2 )
Testmethod ( 1 ) Continuity .
Testmethod ( 2 ) Continuity .
Zs = Ze + ( R1+ R2 ) Formula – Calculating – Earth – Loop – Impedance.
Two/ Point HERE . 2391-10 . Do NotUse The Wording(s).
Multi – Function – Tester . ( MFT ) Ambers doing Handstands on this Matter . Give -&-s what they want to HEAR . Professionalism. Not a D.I.Y. er :89:
Thisgoes for you as well 2392-10 . Combined Instrument that can perform all the requiredTests ( Not a “ PartP or 17[SUP]th[/SUP] EditionTester) ◄◄◄
►►Right Chaps . We keep this for On Site Only . “ Megger “ SlangTerm for an Insulation Résistance Tester .
UsefulJunk .
Termedan “ Extraneous-Conductive-Part
Water Pipe “ Not part of an Electrical System /Equipment . Froma Tester point of View .
P/27. Regulations / OverloadCurrent . An Overcurrent occurring in a circuit which is “ ElectricalSound “
Example– To much plugged into a KitchenRing ?? Washing machine / Tumble Dryer . Kettle . Toaster . T.V. :89:
2392-10 . PS. I can only give Guidance . Remember . as a Designer . The Kitchen Ring Final Circuit is always 100% / Maximum Demand . Yeah . Table1B . Colum 9 .
Point to Note : ( kW ) ◄◄◄◄ ► Real / Power . Yeah :89:
Watchyour Wording here . Yeah ( LV) Regulation(s) . p/31 .
Low / Voltage :
AnyVoltage in a Domestic Installation . ABOVE - ( 50V ) → Band 11Circuits .
AnyWiring that carries ( Main Voltage ) → Band 11
Certification& Reporting . 2392-10 . :6:
Minor Electrical InstallationWork Certificate . -&-s (- This is the documentthat must be Issued if an Existing Circuit is Worked On .
ThePart P ( BR ) BuildingRegulations :smilewinkgrin:
Ineffect you have to .
Design ) The installation . soit is safe as it can be . ( P1 ) ElectricalSafety ( BR)
Install : The wiring &accessories to the standard of BS-7671 .
Inspect & Test : Your new work for compliance with BS-7671 .
Certificate : The work you havecompleted in compliance with BS-7671 .
Apprentices(- Ohm- Law . is the cornerstone ofelectrical calculations .
Referringto the Triangle ( Four Values ) V . I .R . & Z . – ( R or Z)
Symbol– ( V ) : Meaning – Electrical “ Pressure “ : Unit / Volt : Unit Abbreviation ( V ) :
Symbol– ( I ) : Meaning – Electrical “ Current “ : Unit / Amp : Unit Abbreviation ( A ) :
Symbol– ( R ) : Meaning – Electrical “ Résistance “ : Unit / Ohm : Unit Abbreviation ( ):
Symbol– ( Z ) : Meaning – Electrical “ Impedance “ : Unit / Ohm : Unit Abbreviation ( ):
Ifwe Compare an Electrical Circuit to a Garden Hosepipe .
•When you turn on the Water to the hose – The system will stabilise to a steadyflow .
•The pressure is constant & a set current is flowing .
•The flow is governed by the ( Bore ) résistanceor impedance of the pipes “ And “ the pressurepushing the water along .
Apprentices(- if you crimp the pipe . The waterwill slow down . This is because the résistance orimpedance of the pipes ( has just increased ) :- Therefore .
Toget the same current flowing again you have “ TwoChoices
-Turn up the pressure to increase the FLOW
-Decrease the résistance / impedance by removing the “ Obstruction“ of the pipe .
Canyou work this as . More or Less the same with Electrical Circuit (s)
As I can not download Picture YET . am Working on it ?? Electrical -Drawing ◄
Wewill use ( R ) as you know it is the Symbol forelectrical résistance or loading . ( Scenario- Table Lamp at your bedside )
[V = 10V . I = 5A . R = Ω ] -→ > 5A -→ R = ?Ω ← 10V →. R = V/I – R = 10V ÷ 5A = 2Ω
[V = 100V . Z = 1000Ω . I = A ] -→ > I = ?A -→ 1000 = ← 100V → . I =V/Z – I = 100 ÷ 1000 = 0.1A
[I = 100A . R = 1.0Ω . V = ?V ] -→ > 100A -→ 0.1Ω ← V =?V → . V = I x R - V = 100 x 0.1 = 10V
Part( 1 )
Keepit Short for Understanding . :smilewinkgrin:
Firstly (- Themost important thing to remember . inany -&-s . ( ADS ) Automatic Disconnection of Supply . 17[SUP]th[/SUP] Edition 2008 . / Red Book – 415.1.1.
Thisis a primary method of protection from Electrical Shock .
-&-s point of View (- Insulation . Barriers . Earthing. MCBs. These four will stand you fast on (ADS ) RCDs . “ Testing “
Asyou are heading towards 2392-10 .
Earthing . Does a RCD need . “ Earthing “ . Important -&-s . What is the reason for EarthLoop Impedance . ?? Before we test any RCDs . ????? HINT / CPC
wouldan Earth Fault Loop Impedance test . ( Zs ) becomplete without an Earth / Polarity . ( Everything has aknock on effect ) for Testing .Yeah
Barriers . 2392-10 point ofview – 416.2.2. Top of ConsumerUnit ( CU ) IPXXD or IP4X . ( Shallbe possible ONLY by the USEof a key or TOOLScrewdriver+
Barriers . 2392-10 point ofview – 416.2.4. Side & Bottom of Consumer Unit ( CU ) or IPXXB or IP2X . ( Shallbe possible ONLY by the USEof a key or TOOLScrewdriver+
2392-10. IP Rating : Arating given an “ Enclosure “ to describe its “ Résistance “ to ( Solids &Water Intrusion ) it is expressed in Numbers . IPX4 ??
Insulation . Insulation Resistance . ( IR ) They are not Crossed / Polarity . ? ( ifit is not . Initial Verification / Age / Wear& Tear on Cable(s)
Insulation . Where they are no breaks in the Cable(s)Dead-Short . ( Fit for its Extended Use )
Insulation . Can we use the Term ? Fault / Finding . Insulation Resistance .
MCBs . To ensure correctprotection form “ Overloads “ it is Importantthat the “ Protective Device - MCB “ operatingcurrent ( I[SUP]2[/SUP][SUP][/SUP]) is not bigger than ( 1.45 / times ) the current capacity of the Cable ( Iz ) The rating of the MCB - ( In ) MUST not beGreater THAN the CABLE carryingcapacity ( Iz )
Asfrom -&-s point of View - OperatingCurrent of the protective device is always larger THANits RATED VALUE .
2392-10point of view – 514.1.2. Installation of Cables . I canStress this Enough ◄► Identification & Notices . Thiswill bring out the Professional side ofyou . “ Tester “
( T ) As Far as is reasonably practicable . wiring hallbe so arranged or marked that it can be Indentified for – Inspection / Testing/ Repair or Alteration of the Installation .
(Can we say here . “ Maun Bonding Conductor has to be Identifiable “) If One has to Test it . would it safe Time / Money . ???
Part( 2 )
AsDesigner in the Making :smilewinkgrin:
Regulation(- Chapter 521.3. p/97 ) Types of WiringSystem .
TheRegulations are giving you Examples . Yeah .
Table4A2 – gives Examples of installation methods of cables includingreference methods for obtaining Current-Carrying-Capacity whereit is considered that the same current-carrying-capacities can safely be Used .
TheRegulations always gives an Option 99.9% itis Not Implied that such Methods must be Employed or that Other Methods are Prohibited. Etc . Learning Curve
WhereExams are concerned . ( Earthing &Bonding are Two DifferentMeanings ) 2391-10 / 2392-10
Apprentices(- The regulations require the Earth to be HALF the SIZE of the Main CircuitConductor .
The- Whys . The Main Earthing Conductor . 543.1.3. States that where it is Desired Not toCalculate the minimum size of a Protective Conductor.
(Using the Adiabatic Equation ) Table 54.7 . p/130 . Should be Used -
2392-10- As you know The size of Mater Tails in Domestic Installation(s) is 25.0mm[SUP]2[/SUP] - Read this Carefully
Table54.7 . Half the LineConductor size would be ( 12.5mm )
Froma Designers point of View – Manufactures do not produce this SIZE . So the next size UPwould be ( 16.0mm[SUP]2[/SUP] )
2392-10– Table 54.8 . p/134 . Minimum cross-sectional-area of the Main ProtectiveBonding Conductor .
Note : Local Distributors Networkconditions may Require a Larger Conductor . ( DNO )
Apprentices(- Continuity Testing – Test performedon a circuit to make sure the Earth Reachesthe End of it . Yeah .
Circuit-Protective-Conductor . ( CPC ) -&-s
Earthing-Conductor Regulation . p/32 .. This cable is the Last Path out of the Domestic Installation . for Fault / Current . itconnects the system Earth to the Main-Earthing-Terminal . ( MET ).
Main-Protective-Bonding-Conductor .Earth cable that is run to the Main/Incomer of any service to a DomesticInstallation . Usually – Gas . Water .
Fault Protection . ( ADS ) Regulations . 411 .
Thisis a System of putting in place a Protection against ElectricShock . in the Event of a Fault Situation. ( This takes us down many Paths . Yeah. for this matter ADS )
Overcurrent ” a current flow in a circuit which is ( Greater ) than the ( Rated )current carrying capacity of the cables . :89:
Thiswould normally be due to a Fault on the Circuitor Incorrect Cable .
Ifa ( 20A ) cable protected by a ( 32A ) MCB was loaded by ( 25A) the cable would Overheat & the Device would continue to allow current to flow – This couldDamage the cable . ( Iz)
A Fault Current is a current which is flowing in acircuit due to a Fault ??
A Nail is driven through a cable causing an Earth Fault or a Short-Circuit Fault .
Thiswould cause a ( Very High Current to Flow ) through the circuit . Which must be( Interrupted ) before the Conductor reach a Temperature that could Damagethe Insulation or even the Conductor(s) .
TTSystems .
FinalCircuits that are rated UP to & ( 32A ) require a maximum disconnection time of ( 0.2sec) 41.1.
Distributioncircuit require a maximum disconnection time of ( 1 second ) 411.3.2.4
Ihave not done any TT Systems yet . Am working onit . Amber . ( Youwill get this on 2392-10 ) thisis a start . Yeah :coolgleamA:
Apprentices. → 411.3.2. 1. Final Circuits that are rated UPto & ( 32A ) Look First is it ?? TN- or TT ◄◄ :6:
Apprentices. Look in 41.1→ The Regulations are telling you . - requirea maximum disconnection time of ( 0.2sec ) TT :6:
ElectricShock : ( Earthing comes into Exams a Lot )
Two– Ways in which we can be a risk .
i)Touching Live parts of equipment or system that are intended to be Live .
ii)Touching ( Conductive-parts) which are not meant to be Live . but havebecome Live due to a Fault . ( Basic Insulation Fails )
( Conductive-parts ) associatedwith the second of these can either be ( Metalwork )of Electrical Equipment & Accessories ( Class 1) & that of electrical wiring systems such as ( MetallicConduit ) & ( Trunking ) etc called (Exposed-Conductive-Parts )
orother ( Metalwork ) such as ( Pipes ) ( Radiators) ( Girders ) called ( Extraneous-Conductive-Parts )
17[SUP]TH[/SUP]Edition - P/24
( Extraneous-Conductive-Parts ) A ( Conductive-part) liable to introduce a potential . generally Earth Potential. & not Forming part of the ElectricalInstallation
( Extraneous-Conductive-Parts ) NOT ( Forming part of the Electrical Installation )
17[SUP]TH[/SUP]Edition – p/21
( Class 1 ) Equipment in which protection againstElectric Shock does NOT rely on Basic Insulation Only .
Butwhich includes means for the ( Connection of Exposed-Conductive-Parts ) to a ( ProtectiveConductor ) in the Fixed Wiring of the Installation . BS-EN 61140) :28:
BS-EN 61140 ) Protection against Electric Shock . :28:
Commonaspects for Installation & Equipment requires That :-
• (Hazardous-Live-Parts ) . Shall not beAccessible .
• (Accessible-Conductive-Parts) Shall not be Hazardous-Live when there is ( No Fault or UnderSingle FaultConditions )
BS-EN 61140 ) States that those ( ProtectiveMeasures ) providing protection under normal conditions ( That is . When no Faults Exits) provide Basic Protection & those ( Protective Measures ) giving protection Under Single Fault Conditions provide Fault protection– Sec 410 . refers
Themeasures of protection by ( Automatic Disconnection of Supply)
Regulations/ 410.3.3.
- DoubleInsulation .
- ReinforcedInsulation .
-Electrical Separation to Supply to Supply a Single Item of Equipment .
-Extra-Low-Voltage :- SELV . or . PELV . are generally applicable
2392-10. ( Automatic Disconnectionof Supply ) is the MostCommonly Employed method for Electrical Installation(s) .
TheWhys .
- Double & ReinforcedInsulation are more frequently encountered in ( Items)
- Electrical Separation . SELV/ PELV . are only Applied to ( Specific Parts of an Installation)
- Basic/ Protection . ( Protective Earthing )
- Barriers. ( Main Protective Bonding Conductor )
- Enclosures. ( Automatic Disconnectionof Supply ) in the Eventof a Fault .
- Obstacles. ( Automatic Disconnectionof Supply ) for the PrimaryCircuit & connection of ( Exposed-Conductive-Parts ) ofthe Secondary Circuit connected to the ( Protective Conductor ) of the Primary-Circuit ofthe Source .
Point to NOTE : Fictional Extra Low Voltage ( FELV ) ◄◄◄ Equipment so supplied to ( TheProtective Conductor ) -&-s
WhereFictional Extra Low Voltage ( is Employed ) itis necessary to connect the ( Exposed-Conductive-Parts ) ofthe Equipment so supplied to ( The Protective Conductor ) of the Primary Circuit of the Sourcein addition to these Protective Measures required for ( ADS ) Regulation 411.7.3.
Whena Designer ( 2391-10) is considering the Use of ( Obstacles or Placing Out of Reach ) to provide Basic / Protection. it is strongly recommended that careful consideration be given to the ( Statutory Requirements ) relating to :-
• System. work activities & work equipment ( Regulation / 4. of the Electricity at Work Regulation 1989 )
•Insulation . Protection & Placing of Conductors ( Regulation / 7 . of the Electricity at Work Regulation 1989 )
•Work On or Near Live Conductors. ( Regulation / 14 . of the Electricity at WorkRegulation 1989 )
Earthing . or other suitable precautions . (Regulation / 8 . of the Electricity at Work Regulation1989 )
•Working Space . Access & Lighting . ( Regulation / 15. of the Electricity at Work Regulation 1989 )
•Person to be “ Competent “ to prevent Danger& Injury . ( Regulation / 16 . of the Electricity at Work Regulation 1989 )
►►► Wording /NOT Act . ◄► But . Law . Exams ( Electricity at Work Regulation 1989 )
( Electricityat Work Regulation 1989 ) is ( law ) in the United Kingdom. ◄◄◄ in Exams / Wording is ( LAW )
ConsumerProtection is an ACT ◄◄◄ :75:
( Electricityat Work Regulation 1989 ) Applies to all ElectricalSystems at ( All Voltages )
2391-10- Inspection & Testing: ( Remember two different Words ) Yeah. 2392-10
Inthe case of most Types Electrical Installation there is ( No Statutory Requirement ) to carry out ( Inspection & TestingPeriodically )
Itis . However . A Commonly adopted practice seen as a Means of Meeting the Maintenance“ Obligations
The. Electricity at Work Regulations 1998. Regulation ( 4 ) & the Housing Act 1985 –Section 11 . BS-7671 is in the Most Part concerned with the Design .Installation . & Initial Inspection & Testing of New Installations
Chapter62 .
Containsa number of Requirements relating to ( Periodic Inspection & Testing ) . Regulation. 622.2. States that ( PeriodicInspection & Testing ) is not required an Effective Management SystemOperated by ( Skilled Persons ) covering itsMaintenance .
However. & as has been Mentioned Previously .
( The Person Responsibly may be Held Accountable in the Event ofan Incident Occurring )
(2391-10 ) Appropriate Records must be Keep of the Maintenance ActivitiesUndertaken . ( Cover ones But . Yeah ) :75:
UsefulJunk .
Ambersof on One .
ImportTerms . that -&-s . will bring up in Exams .
Statutory& Non- Statutory Regulations .
Electrical Systems .
TheBuilding Regulations ( Part P )
Instruments .
2392-10. Firstly .
Foryour Assessor ?? are you aware of the Statutory& Non- Statutory Regulations that are relevant to InstallationWork
Tester. Example . Insulation Résistance.
i)The Range of Instrumentrequired . ≥ 0.5MΩ / 0.1MΩ .
ii)The Requirements regarding the Use & Performance of Test Equipment .
The more you put in the Easier it Becomes . :icon6:
Asan Inspector . You have to consider the Implicationswhen carrying out an Inspection & Testing . ( Of an Installation ) :13:
Inspection& Testing . Certification Required .
InitialVerification .
PeriodicInspection & Testing .
( 2392-10 ) Initial Verification (- New Work & Alterations & Additions . ( TheCertification ( EIC ) Electrical InstallationCertification .
(2391-10 ) Periodic Inspection & Testing . for ExistingInstallations . ( TheCertification ( PIR ) Using Wording – Condition Report . ( PeriodicInspection Report)
►► Both must be accompanied by a ( Schedule of Test Results & Schedule ofInspections ) (EIC ) / ( PIR )
2392-10 – Exams . STATUTORY & NON- STATUTORY REGULATIONS .
Thestatutory regulations the apply to ( Electrical Work) 2392-10 / Initial Verification / NEW INSTALLATIONS . only
Let’skeep the Assessor . Happy . Yeah
TheHeath & Safety at Work . ( ACT ) ◄
TheElectricity at Work Regulation 1989 . ( Law )
2392-10.
The Building Regulation Part / P . ( Domestic Installation ) Yeah (This will guide you back to BS-7671 ) onMatters
BS-7671:2008/ British Standards . Non- Statutory Regulations. ( By using BS-7671 . You are complying with :- ( 2)
TheHeath & Safety at Work . 1974 ( ACT )
2392-10. ( As an Inspector ) -&-swill use the wording ( Inspector / You ) → → → → Not ( Tester ) Fail :grouphug:
Amberof on One again .
ThisForum is here to HELP& Guide you on Matters .
Froman Exam point of View . 2391-10 . ( NotMeggers here )
( Electricityat Work Regulation 1989 ) Wording / Your Test Instrument / Sourceof Energy . Mains- Power / Battery ???
YourTest Instrument ?? Continuity Tester. is a Test on the System in itself . -&-s want to here . “ Continuity Tester “ Etc
2392-10/ Loop Impedance Tester . ( Live Test )
( Electricityat Work Regulation 1989 ) Which requiresan ( External Supply Source ) ≈ ≈ A.C. – becomes part of the System into whichit is Connected .
Point to Note . Here . Amber . :rockon:
Withoutany Thank You . I don’t know if am in the Right Direction . :43:
Pleasehit the ( Like Button ) it does help me OUT. PS. What’s a click on the Button. ( A Lot To Me )
UsefulJunk .
Apprentices(- Earth Fault Current . ??
AnOvercurrent resulting from a ( Fault ) of ( Negligible Impedance ) between a Line Conductor & an ( Exposed-Conductive-Part ) or a ( ProtectiveConductor )
2392-10(- Protective Conductor Current ) “ Meaning “ ( Earth Leakage Current) Deleted / BS-7671:2008 ◄◄ :33:
Acurrent which flows to Earth . or ( Extraneous-Conductive-Parts ) in a circuit which is ( Electrically Sound )
Thiscurrent may have a ( Capacitive Component )including that resulting from the ( Deliberateuse of Capacitors )
17[SUP]th[/SUP]Edition . p/27 .
( Protective Conductor Current ) Electric current appearingin a ( ProtectiveConductor ) . Such as ( Leakage Current )or Electric current resulting from an ( InsulationFault . ) :19:
UsefulJunk .
Tocomply with the Electricity at Work 1989 . & BS-7671:2008.
It is necessary . in appropriate circumstances . Toprovide means to “ Provide “ means to “ Prevent “ any equipment from being Inadvertently or unintentionallyEnergized .
Safe Isolation . ( Padlocking in the Isolated Position )
BS-7671:2008. No VoltageLimitations are Specified . Yeah :19:
Electricityat Work 1989 / Reinforces this ( Regulations apply to all System )
BS-7671:2008. 2392-10 – These are Designed toEncourage Good Practice . Yeah .
Ihave Knocked something Up . in wording .to help you along the Way . Amber . :thinking2:
Thefollowing Test results . States what tests have been performed & which meter has been used .
( Ω) • Low-résistance ohmmeter / Continuitytester .
(MΩ ) • An Insulation résistance tester .
( Ω) • A Loop impedance tester .
(mA ) • A residual current device ( RCD ) tester …….. -&s / GN-3. ( Test instrument should not beoperated for longer than ( 2 seconds )
(kA ) • A prospective fault current ( PFC ) tester .
( Ω) • An earth electrode résistance tester .
An approved test Lamp orvoltage indicator ……. GS-38
A Proving Unit …….. ( Thisis an Optional item of Test equipment )
Insulation Résistance test isthe correct term for this form of testing .
Loop Impedance tester .
Thisinstrument functions by creating . in effect . an “ EarthFault “ for a brief moment . & is connected to the circuit via a Plug or by “ Flying Leads“ connected separately to Line . Neutral . & Earth.
( The instrument should only allow an Earth Fault to exist for a maximum of ( 40mS ) &resolution of ( 0.01Ω ) is adequate for circuitsup to ( 50A )
PFC tester .
Normallyone half of a dual loop Impedance ( PFC ) tester . This instrument measures the prospective ( Line Neutral FaultCurrent )
atthe point of measurement using the same leads as for ( LoopImpedance )
Shouldbe Banned (- “ NeonScrewdriver “ which encourages the passage of Current . at Low-voltage .Through the body .
Proving Unit :
Thisis an Optional item of Test equipment . in thatTest Lamps should be proved on a known Live Supplywhich could . of course be an “ Socket Outlet/ Lighting Point )
TestLamp on such A Known Live Supply may involve entry into “ Encloses “ with the AssociatedHazards
-&-s. Point to Note . TestLamps must be Proved against a ( Voltage Similar ) to that to be Tested . ( 230V.. Lamp ) ??????
BS-7671:2008. requirements .
AnElectrical InstallationCertificate can be issued only by the Installerresponsible for the Installation Work . :oops: BS-7671:2008
UsefulJunk .
Asyou Know . Maximum Touch Voltage ( 50V )
TT/ Electrode of 100Ω & RCD of 300mA. What would the Touch Voltage Be???? :oops: 100 x 0.3 = 30V - Touch Voltage .
***Cont../ Useful Information for Electricians & Apprentices***
Australia
amberleaf,
Dan,
