The most effective way ofTesting for ( Earth Faults) in the wiring or equipment is byMeasuring the Insulation Résistance . as described in Section 6 . 612.3.1.
( Nobreakdown of the Conductor Insulation ) Nails . & Picture hooks . Screws . ???????????? :svengo:
2392-10 .
Floorboards’ Nail driven between the Neutral & Earthconductor(s) creates a ( Neutral to Earth Fault) :hurray:
“ RCD to Trip “
The Fault can be located byInsulation Testing .
Damaged cable must be replaced& either relocated to avoid further damage or protected .
2392-10 :- Requirements to protect cables from Impact& Penetration are given in Regulation 522.6.5. ( v ) p/100 . 522.6.5. the same . ( v ) p/124
Section 712 :
Solar Photovoltaic ( PV ) Power Supply System(s)
712.512 : p/243 Accessibility.
712.513.1. The selection & erection of equipment shall facilitatesafe maintenance & shall notadversely affect provisions made by themanufactures of ( PV ) equipment to enable maintenance or service work to becarried out safely .
Scope .
Section 712 of BS-7671:2008 - ( Applies to the Electrical Installationof ( PV ) power )
Supply systems including system(s) with a.c. modules .
Note )- Section 712 does NOT apply to ( PV )power supply system(s) which are intended for ( Standalone Operation )
New Topics covered . On-Site Guide is Portable Generators .
Two classes of ( TemporaryGenerators ) – (i) Portable Generators .(ii) Mobile Generators .
Generators used for short periods :- One-day & these used for longer timescales .
□ Portable generators with an electrical output rating of up to( 10kVA ) used for small scale work –short term use ( Less than one day )
□ Mobile Generators . used for longer periods & can be in Excess of (( 10kVA ))
• Portable generator used with a Floating Earth .
• Portable generator used without reference to the general mass ofthe Earth .
• Portable generator referenced to the general mass of the Earth .
Permanent use of Generators . Guidance Note 5 - Guidance Note 7 .Section 551 . BS-7671:2008 / 2011 .
Generator(s) are used to ( supply Concession Vehicles ) such as (Burger Vans ) look Section 717 . Mobile & Transportable Units . / GuidanceNote 7 .
Temporarily supply electrical equipment or electricalinstallations with a generator where the mains or usual supply is Unavailable .
Portable generator with Floating Earth :
Small portable generators’ . ranging in ( Output ) from 0.3kVA / 10kVA single phase often have a ( Floating Earth )
Connection of the Socket-outlet of the Unit to the ( Neutral ) of the generator winding.
The ends of the generator winding are brought out to one or more (Three-pin socket-outlet(s) which should conform to BE-EN 60309-2.
[ The Earth socket-tube ofthe socket-outlet(s) are usually connected ( Internally to the Frame of the GeneratorOnly ] ► This arrangement is a form of ( Electrical Separation )
When do NEW INSTALLATIONS have to COMPLY with Amendment No 1 . Requirements
Amendment No 1 July 2011& will come into effect on ( 1 January 2012 ) This means that Installation(s) designedafter ( 1 January 2012 ) will need to comply with the Amendment 1 requirements
An Installation that was designed to the 17[SUP]th[/SUP] Edition “ BEFORE “ 1 January 2012 but gets completed after thisdate should be Certified to the 17[SUP]th[/SUP] Edition
110.2. Exclusions fromScope . :hurray:
First Amendment ( xii )Electric fences covered by BS-EN 60335-2-76 . The rest are thesame . ( i ) - ( xi )
( T ) Testingpurposes :- suitablewarning sign(s) & / or notices shall be provided 2391 / 2392 .
134.1.7. Where necessary forsafety purposes . suitable warning sign(s) & / or notices shall be provided.
134.2. Initial Verification .
During erection & on completion of an installation or anaddition or alteration to an installation . & before it is put into service. appropriate ( Inspection & Testing ) shall be carried out by CompetentPersons to verify that the requirements of this Standard have been met .
Appropriate certification shall be issued in accordance withSection 631 & 632 .
134.2.2. The designer ofthe installation shall make a recommendation for the interval to the firstperiodic inspection & test as detailed in Part 6 .
Note : The requirements of Chapter 34 ( Maintainability ) should be taken into consideration .
135 . Periodic Inspection and Testing .
135.1. It is recommendedthat every electrical installation is subjected to Periodic Inspection andTesting . in accordance with Chapter 62.
Definitions – Part 2 . p/25 .
□ Current-carrying capacityof a conductor .
The maximum current which can be carried by a conductor under specified conditions without its steady-statetemperature exceeding a specified value .
□ Current-using equipment .
Equipment which converts electrical energy into another form ofenergy . such as light . heat or motive power .
Definitions . p/26 . New .to First Amendment :oops:
Discrimination : Ability ofa protective device to operate in preference to another protective device inseries .
Definitions . p/26 . change.
Exposed-conductive-part . :carols:
Conductive part of equipment which can be touched & which isnot normally live . but which can become live under fault conditions .
Conductive part of equipment which can be touched & which is notnormally live . but which can become live when basic insulation fails .
UsefulJunk .
17[SUP]th[/SUP] Edition Wiring Regulations . Requirements forElectrical Installations 2008 . :gettree:
The term ( Phase ) is replaced with the term ( Line )
Line is the Internationallyused term . Do Not confuse ( Line ◄ ) conductor with ( Live ◄ )conductor which can be a ( Neutral ) conductor .
Line Conductor )- p/29 . Definitions
A conductor of an A.C. system for the transmission of electricalenergy other than a ( Neutral ) conductor . A protectiveconductor or a ( PEN ) conductor . Theterm also means the equivalent conductor of a D.C. system unless otherwisespecified in the Regulations .
( PEN Conductor ) p/33 . Definitions
A conductor combining the functions of both protective conductor& Neutral conductor .
Portablegenerator referenced to the general mass of the Earth.
Wherethere are ( Extraneous-conductive-parts ) or ( Exposed-conductive-parts ) fromother electrical systems present .
Generatorreference Earthing by means of an (Earth Electrode ) to the general mass of Earth should beinstalled .
NOTE )- That this does NOTcreate a ( TT Arrangement ) Thesupply will be ( TN-S ) from the generator but the ( Neutral ) or (Star point ) will be referenced to thegeneral mass of Earth .
( Generator reference Earthing - Using Earth Electrode )
Wherean Earth Electrode is supplied it will need to be tested by the Standard Method using a (Proprietary Earth Electrode résistance tester )
NOTE )- That an Earth FaultLoop Impedance Tester cannot be used for this Test as the Earth Electrode is NOT used as a meansof Earthing it used to reference the portable generator to the general mass ofthe Earth . As the Earth Electrode isused for referencing & NOT as a means of Earthing . The résistance should .( Ideally be Less than 200Ω )
If buried . generator reference Earthing&/or Bonding conductors should be sized in accordance with Table 54.1. & suitably protected in accordancewith Regulation 543.3.1. Whererestrictions . such as concreted / paved areas or the portable generator isbeing used some distance above ground level . make it impossible to install anEarth Electrode . ( Simultaneously )accessible metal parts . i.e. accessibleExtraneously-conductive-parts or Exposed-conductive-parts from other electrical systems . may beBonded to the ( MAIN ) Earthing Terminal of the generator .
Whereseparate accessible Extraneous-conductive-parts or Exposed-conductive-parts from other electricalsystems are connected together . protective conductors can be sized inaccordance with Regulation 544.1.1.
Importantto Emphasise that Generators must be Used in “ Accordance with the Manufacturers Instructions “ :iagree:
WhereGenerators are ( Hired from plant-hire companies ) it is ( Responsibilityof the plant-hire company ) toprovide the Hirer with Information regarding the Safe use of their Equipment . Underno circumstances should Hirers attempt to change the Internal electricalconnections of Hired Equipment .
Where( Doubt Exists ) as to the Internal Earthing connectionsof the generator . a ( Continuity Testbetween Neutral & Earth socket-tubesat the socket-outlet can be undertaken ) Very Low reading – Less than ( 0.1Ω ) wouldindicate that it is not a generator with ( Floating Earth)
Responsibilitiesof the Duty Holder :carols:
Minor Electrical Installation Work(s) Certificate .
( Requirements for Electrical Installations BS-7671 [[ IET Wiring Regulations ]]
To be Used only for minor electrical work which does NOT includethe provision of a NEW circuit .
System Earthing Arrangement . TN-C-S □ - TN-S □ - TT □
Part 2 )- Installation details . Comments on existing installation . Includingadequacy of ( Earthing & Bonding ) arrangements ( T -&-s ) Regulation 131.8. )
131.8. Moved by BS-7671:2008 Amendment No 1 to 132.16 . ◄ p/393
( T -&-s ) 132.16. p/20 .
Additions & Alterations to anInstallation .
No addition or alteration . temporary orpermanent . shall be made to an existing installation . Unless it has beenascertained that the rating & the CONDITION of any EXISTING EQUIPMENT . including that of the distributor . will beadequate for the altered circumstances . furthermore . the EARTHING & BONDING arrangements . if necessary forthe protective measure applied for the SAFETY of the ADDITION or ALTERATION .shall be adequate .
Definitions – Part 2 : p/31 (NEW ) First Amendment :carolers:
Minor Works .
Additions & Alterations to an installation that do not extendto the provision of a new circuit .
Definitions – Part 2 : p/31 / p/28 :christmaswreath:
From a Inspectors point of View.
Reporting : Communicatingthe results of ( Periodic Inspection& Testing ) of an electricalinstallation to person Ordering the Work .
Standard ( PVC )Insulated Cable(s) are designed to operate at Temperature’s up to ( 70°C ) beyond this there is a risk of Damage . :gettree:
p/340 . Table 4D5 - ( 70°C ) Thermoplastic Insulated & Sheathed flatcable with Protective Conductor - ( Copper Conductors ) T&E .
Cableis guided by two main principles’ .
i)Cable should be able to carry the current load ( Imposed ) on it without ( Overheating )
(( Extreme conditions of temperature it willencounter during its Working Life . ))
ii) You should have sufficient sound Earthing - Limit the voltage to which people areExposed . Safe Level . ( Fault Current to trip MCB inshort time . )
OverCurrents can be Classed into two types
Overload )- An overload occurs when a current flows thatis somewhat to High .
□ Overloadsdon’t normally cause immediate damage . ( The likelihoodof Damage gradually as the duration of the Overload Increases )
□Cables will Overheat & Melt . (Exposing bare conductor(s)
□ DomesticInstallations Overloads usually results from using to many Appliances at the same time . 2392-10
ShortCircuit )-
□ isa connection between Line & Neutral . OR Line & Earth .
Youare looking for a ( Low Résistance ) & thecurrent that can flow may be hundreds or thousands of times to High for thesystem .
Thiscurrent is called the ( FaultCurrent or Short Circuit Current )
Short Circuit Current . An overcurrent resulting from a fault ofnegligible impedance between ( Live Conductors L/N ) having a difference in potential under normaloperating conditions . p/34
Fault Current : A currentresulting from a Fault . p/28
InPractice )- DomesticInstallation(s) Overload protection& Short circuit protection are both provided by the same Device . ( MCB ) or ( RCBO )
Additional Protection . may beprovided by an ( RCD )
Residual Current Operated circuit breaker withIntegral Overcurrent Protection ( RCBO ) designed to perform the functions of protection against Overload & Short Circuit.
“ Resi/ dual “ dual - two - L/N
Circuit Breaker : ( MCB ) Definitions . p/25 - p/21 :17:
A device capable of making . carrying & breaking normal loadcurrents & also making & automatically breaking . under pre-determinedconditions . ( Abnormal Currents )
Such as ( Short Circuit Currents ) . it is usually required to operateinfrequently although some types are suitable for frequent operation .
