A
amberleaf
T&E– cable PVC clipped to a ( Joist )above a ( Plasterboard) ceiling completely surroundedby ( Insulation exceeding 100mm ) … C.C.C. …
1.0mm[SUP]2[/SUP] = 10.5A . - 2415 Watts . ( Calculations’ - 10.5 x 230V = 2415 Watt )
1.5mm[SUP]2 [/SUP] = 13A . ( Calculations’- 13 x 230V = 2990Watt )
2.5mm[SUP]2 [/SUP] = 17A . ( Calculations’ - 17 x 230V = 3910Watt )
Table4D5 . BS-7671:2008 – No 1 2011 . Installation ref . method 101# .
Evenif you take the lower … C.C.C. … of (8A ) for 1.0mm[SUP]2 [/SUP] T&E cablecompletely surround by insulation for over ( 500mm ) its Still gives you up to ( 1840 Watts )
Cable’sshould be routed so as they are NOT covered by or touching insulation wheneverpossible also length of run & potential Volt – dropto be considered . ( Vd )
523.9. p/128 . Cable’s in thermal Insulation . ( Table 52.2. – p/129 )
Quote. Wherenecessary . The nature of the load ( e.g. cyclic ) & diversity shall be takeninto account .
http://www.electrical.----------/wiring-matters/15/current-ratings.cfm?type=pdf …….. ◄◄ ( Good Reading ) surround by insulation
Just a Reminder . 2392-10 .
6A– MCB . ( 6 x 230 = 1380W … design load max )
Method - C* … clippeddirect
1.0mm[SUP]2[/SUP] = ifjust clippedto a wall . ( Surround by Air) . will take up to ( 16A )
1.5mm[SUP]2[/SUP] = ifjust clippedto a wall . ( Surround by Air) . will take up to ( 20A )
2.5mm[SUP]2[/SUP] = ifjust clippedto a wall . ( Surround by Air) . will take up to ( 27A )
► Zs – ( Max ) ◄◄ Maximum permitted Earth-faultLoop Impedance .
Table. 41.2.
Table. 41.3.
Table. 41.4.
Table. 41.5. – for Non-delayed RCDs .
Table. 41.2.
Table. 41.3.
Table. 41.4.
