Guest viewing limit reached
A
amberleaf
O.S.G.. The use of other methods’ of determining Maximum Demand is Not Precludedwhere Specified by the Installation Designer
FirstlyI make no Apologies for the Way am Writing on any Matters . it can be a first day Apprentice or some one Needing aJog of Memory .
Sowe are all in the Same Boat . “ To Learn “
For the Apprentices . The Day we stop learning is the Day we hang Upour Tool-Bag
CookerDesign Current Calculations
Thefirst thing you have to do is get Your Head around the Calculations !!
(From a Design point of View ) 2392-10
DomesticInstallation Oven(s) & Hob(s) are to be Calculated upon their MAXIMUM LOADING
Startwith a simple Calculation ( An Oven has a rating of 2kW ) 2000
(I = P/V ) Formula … I = 2000 ÷ 230V = 8.70A …. Weare Using the Unit Amps
2392-10/ Domestic Installation Oven(s)
Ovenhas 4 Rings ( 2 x 1kW ) & ( 2 x 1.5kW ) & Grill ( 2kW ) & Oven (3kW )
-Controlled via a CookerSwitch with a Socket outlet .
Asa Designer . we’ll have to Apply Diversity ??
Important )- Diversity allowance to be Applied to the FULL LOAD CURRENT for CookingAppliances .
TheO.S.G. is telling us . Purpose of the Final Circuit fed from theConductors )
O.S.G.Table 1B p/97 – column (3) Cooking Appliances → At the Top of the Page Note : Type ofPremises ( 2392-10 → Household Installations ) Domestic Installation(s)
DomesticInstallation(s) Only O.S.G. - 10A + 30% f.l – Full Load ) of connected Cooking Appliances in the Excess of 10A+ 5A if a socket-outlet is incorporated in the Control Unit . ( C.C.U. ) – 45A + 13A Socket Switched with Neon .
Fromyour point of View ( The First 10A ofthe rated current plus 30% of the reminder ( Plus) 5A if the Control Unit incorporates s Socket.
Calculations)- You bank “ Hold OFF“ the first 10 Amps of the Maximum Load Current )
The10A will be used at the End of the Calculations’
-So your Work out the Total Power Rating & then calculate the Full Load Current
Calculations)- Power = ( 2 x 1 ) + ( 2 x 1.5 ) + ( 2+ 3 ) = 10kW
I= 10000 ÷ 230V = 43.48A … round it up to the first four numbers43.47826087 ( 48 ) 43.48A
UsingDiversity allowance stated ↑↑ ( 43.48A sub 10A = 33.48A )
I= 33.48 x 30 ÷ 100 = 10.04A
Youradding the ( 5A ) for Socket outlet . I = 10A + 10.04 + 5A = 25.04A )- Asa Designer this is your Expected Current Demand .
Remember )- Supply Cables Rated to suit DesignCurrent ( Iz ) :)
This is a Live Test “ .
415.1.1. –. Additional protection : RCDs
It only works if the RCD is Energised
Regulation RCD effectiveness of any testfacility incorporated in the device
To Ensure . The test buttonshould operated at intervals of not greater than 3 months . BS- 514.12.2. p/118..
H&S . Legislation .
The Electricity at Work Regulations 1989 . specificallydeal with Electrical “ Systems “ Regulation 4 .
i) All “ Systems“ shall at all times be of suchconstruction as to prevent . so far is reasonablypracticable . Danger .
ii) As may benecessary to prevent “ Danger “ all systems shallbe maintained . sofar prevent . so far as is reasonablypracticable . Danger .
iii) Every work activity . including ( Operation ) use & maintenance of a sytem &work near a system . shall be carried out in such a manner as not to give rise. so far is reasonablypracticable . Danger .
iv) Any equipment providedunder these Regulations for the purpose of ( ProtectingPerson(s) at work on or near Electrical Equipment shall be suitable for the use for which
it is provided . etc .
415.1.2. An RCD is not used as the solemeans of protection & does not obviate the need to apply one of theprotective measures specified in section 411 to 414 .
- AnRCD is not used as the sole means of protection against Exposed live conductors.
Wiring regulation 17[SUP]th[/SUP] Edition – 2011
Which . amongst other requirements .specifies therequired methods for safe Fusing & Earthing . 415.1.2. The single most important precautionagainst Electric Shock is a properly constituted Earthing System supported by ( Fuses or MCBs ). To correctlydisconnect the supply in case of Overcurrent or Fault to Earth .
For “Portable Units “ the Test Button shouldbe operated before every use at a new site to ensure that it isFunctioning .
You know the outcome . Any device failing to Trip must be removed from service .
612.13.: Functional testing . 2392-10 . last test .
i) Where ( ► Faultprotection ) & / or ( ►Additional protection) is to be provided by an RCD .
ii) The effectiveness of any test facility incorporatedin the device shall be verified .
Determining the Protective DeviceCharacteristics’ . “ MCB “ p/38
Main formula .
( Iz > In > = Ib )
433.1.1.:
Ib ) –Design current of circuit ( A ) Load to be connected tothe circuit . :
Table 41.3.
In ) – Ratedcurrent or current setting of protective device ( A ) .
433.1.1.
Iz ) –Current-carrying capacity of a cable for continuous service under theparticular installation conditions concerned ( A )
This means that in every circuit at all times thecurrent carrying capacity of the cables must be ( Higher ) than the ( Highest ) possible load current .
The ( Protective Device ) rating must be ( Higher ) thanthe ( Load Current ) but ( Lower ) than the maximum current carrying capacity ofthe ( Cable ) installed
-&-s 2392-10: RCDs “ MUST “be used in conjunction with an “ Overload ProtectionDevice “ such as MCB .
-&-s 2392-10: RCD . Double-poleswitching types are preferred to ensure full isolation should a fault occur .
RCD: Hazards .
RCDs– don’t offer protection against current Overloads .
RCDs– will NOT protect against a socket outlet being wired with its Line &Neutral terminals the wrong way round .
RCDs– will NOT protect against the overheating that results when conductors are NOTproperly screwed into their terminals
RCDs– will NOT protect against Line & Neutral shocks . because the current inthe Line & Neutral is balanced . so if you touch Line & Neutralconductors at the same time . ( bothterminals of a light fitting ) you maystill get a shock .
2392-10 : Visual Inspection . 611.1. to 611.3.
“ Inspection “ shall precede testing & shall normally be donewith that part of the Installation under Inspection ( Disconnectedfrom the Supply )
Continuity of Conductors in Ring Final Circuit . 612.2.2.
Purpose of this test is to verify that the Ring FinalCircuit . are
Correctly wired & connected .
Continuous .
-&-s. Not interconnected / Bridged
Earth Electrode Résistance .612.7.
Where the Earthing System incorporates an EarthElectrode as part of the Installation , The Electrode résistance to Earth shallbe ( Measured )
The Earth Electrode . where used . is the means ofmaking contact with ( General Mass of Earth ) Thus it must be ( Tested) to ensure that good contact is made .
Your main consideration here 2392-10 : To ensure thatthe Electrode résistance . is ( NOT HIGH ) thatthe voltage from Earthed Metalwork to Earth ( Exceed50V ) ◄
Where an RCD . is used This means that the result ofmultiplying the RCD operating current ( in Amperes ) by the Electrode résistance( in Ohms ) does NOT Exceed 50V
If a ( 30mA /RCD ) is used . This allows a maximum Electrode résistance of ( 16667*Ω ) althoughit is recommended ( Table 41.5. – Max Earth Fault LoopImpedance ( Zs )
Earth Electrode résistance should NEVER be GREATER than (200Ω )
2392-10:
Whena New Installation has been Completed , it must be Inspected and Tested toEnsure that it is” SAFE “ to use ,
ThisProcess is known as the Initial Verification ,Regs 610.1 for Safety reasons , the Inspection process must precede Testing ,
Please take the TIME to READ this MATTER . 2391-10 / 2392-10 ◄◄ :13:
This Forum can ONLY give YOU GUIDANCE . ◄◄
What is ( Time ) Money .
Firstly. We are ( All) guilty of NOT reading theQuestions / Rightly. 2391-10 . C&G ?? . :blush5:
C&G ?? Identifythe most suitable test instrument for a set of circumstances C&G ?? . GN-3 . ( Incorrect Instrument Names being Used in Exams ) 17[SUP]th[/SUP] Edition& 2011 .
p/83 . GN-3 . Insulation RésistanceOhmmeters’ .
the instrument used should be capable of developing the( Test ) voltage requires across the ( Load )
[ Instrument conformingto BS-EN-61557-2 ] ◄◄◄
p/83 . GN-3 . Earth Fault Loop Impedance Testers
These instruments operate by ( Circulating ) a currentfrom the Line conductor into the Protective Earth . This will raise thepotential of the Protective Earth System .
For circuits rated to ( 50A ) a Line-Earth loop testerwith a resolution of ( 0.01Ω ) should be adequate . in general . suchinstruments can be relied upon to be accurate down to values of around ( 0.2Ω )
Instruments conforming to BS-EN-61557-3 . will fulfilthe above requirements . ◄◄◄
p/84 . GN-3 . Earth Electrode RésistanceTesters .
this may be a ( Four terminalinstrument ) OR ( Three terminal One ) where a combined lead to the ( Earth Electrode ) would not have a significant résistancecompared with the ( Electrode Résistance ) sothat the résistance of the test leads & temporary spike résistance ( Can be eliminated from the Test Result )
-&-s ?? .Please NOTE (- “ Wording Used “ . ◄◄
It may be HELPFUL to NOTE thatInstrument complying with ( BS-EN-61557-5 ) . incorporatethis facility . ◄◄
p/84 . GN-3 . -&-s ?? . PleaseNOTE (- “ Wording Used “ . ◄◄
Phase Rotation Instrument . BS-EN-61557-7. ◄◄ . gives the requirements for measuring equipmentfor testing the ( Phase Sequence in Three-phase distribution systems .
[ Whetherindication is given by . Mechanical . Visual . & /or AudibleMeans . ]
RCD Testers .
The test instrument should be capable of applying thefull range of test current to an ( In-service ) accuracy as given in (BS-EN-61557-6 ) ◄◄
Now -&-s (- Wording Only . 2392-10 Exams . To CHECK - RCD operation & to minimise ( Danger ) during the test . The test current should beApplied ( For No Longer Than2 Seconds ) 2392-10 . This only Appliesto RCD Only . ◄◄◄◄◄◄
2392-10 . The instrument used for ( Low Résistance Tests) 612.2.1. No-load voltage between 4V &24V . & a shortcircuit current NOT less than 200mA .
Instrument to ( BS-EN-61557- 4 ) will meet the above requirements . ◄◄◄◄◄◄
p/81 –GN-3 : Instrument Standard .
The ( Basic ) instrumentstandard is ( BS-EN-61557 ) Electrical Safety in Low-Voltage Distribution Systems. Up to 1000V . a.c. & 1500V . d.c. Equipment for Testing .Measuring or Monitoringof Protective Measures . ◄◄◄◄◄◄
NOTE (-. This Standard includes performance requirements & requires ( Compliance with BS-EN-61010 )
ISBN-978-086341-857-0 . GN-3
Amendment 2011 .
□ Electrical Installation Condition Report .
Electrical Installation Condition Report . ( EICR ) from Appendix 6 of BS-7671 . is for use when carrying out ( Routine ►► PeriodicInspection & Testing ) of an Existing domestic& similar installation . with up to ( 100A ) ( Single – phase ) or ( Three-phase) supply .
►► It isNOT use when ( Alterations or Additions are Made)
A Generic Scheduleof Test Results ( 4 ) & aCondition Report Inspection Schedule ( 7 ) shouldaccompany the Electrical Installation Condition Report ( 6 )
( 6 ) The ElectricalInstallation Condition Report . ( EICR ) to be used for Domestic & SimilarInstallations with ( 100A ) Single – phase ) or ( Three-phase ) supply
( 4 ) Generic Schedule of Test Results .
( 7 ) Condition Report Inspection Schedule . ( forDomestic & Similar Premises with up to ( 100A ) supply .
The ( Forms ) are Numbered .
1 ) . Electrical Installation Certificate . Please Note : (Single – Signature )
2 ) . Electrical Installation Certificate .
3 ) . Scheduleof Inspections . Please Note : ( for NEW Installation Work Only )
4 ) . GenericSchedule of Test Results .
5 ) . Minor ElectricalInstallation Work Certificate .
6 ) . ElectricalInstallation Condition Report .
7 ) . ConditionReport Inspection Schedule . Please Note : ( forDomestic & Similar Premises with up to ( 100A) supply .
( 1 & 4 ) are designed for use when ( Inspecting & Testing ) a New Installation . or an Alteration orAddition to an ( Exceeding Installation ) forms comprise the following .
1 ) . Short –form of . Electrical Installation Certificate . PleaseNote : ( to be used when oneperson is responsible for the Design . Construction . Inspection & Testing. of an Installation ) OR .
2 ) . Electrical Installation Certificate . ( Standard from Appendix 6 of BS-7671 )
3 ) . Scheduleof Inspections . Please Note : ( foe NewInstallation Work ONLY )
4 ) . Generic Schedule of Test Results . .
-&-s . State the ( TWO ) different types of Inspection & Testing . may require
“ InitialVerification “ … ( Initial Verification & Inspection )
“ Periodic Inspection & Testing “ … ( ElectricalInstallation Condition Report )
-&-s . 2010 . Q ) Identify the Two Types of Test InstrumentIdentified in GN-3 . Which may be Usedto confirm “ Phase Sequencing
GN-3 . 2.7.17. Phase – Sequence . p/54
i) Rotating disctype .
ii) Indictor Lamp Type .
you have correctly Identify these InstrumentTypes . for -&-s
Functional Testing . GN-3 . p/55 (GN-3 & Regulations )
While the following tests are NOTa specific requirement of BS-7671 . it is recommended that they arecarried OUT.
In order to test the effectiveness of Residual CurrentDevices after installation . a ( Series of Tests ) may be applied to check thatthey are within specification & operate satisfactorily . ( Regulation - 612.8.1.) p/193 . & Operate satisfactorily .
This test sequence will be in addition to providingthat the test button is operational . the effectiveness of the test buttonshould be checked after the test sequence .
2392-10 : foreach of the tests . Readingsshould be taken on ( Both Positive & Negative half-cycles & the longeroperating time recorded .0
411.4.5. . Prior to these RCD tests it isessential . for safety reasons . thatthe earth loop impedance is tested to check the requirements have been met .
TN-S . System . example.. 612.8.1. The ( Verification ) of the ( Effectiveness ) of the measure for faultprotection by automatic disconnection of supply is effected as follows .
1) measurement ofthe earth fault loop impedance – see Regulation . 612.9.
2) verification of the characteristics & / or theeffectiveness of the associated protective device . This verification shall bemade .
- for overcurrent protective devices . by visualinspection ( i.e. short-time or instantaneous tripping setting forcircuit-breakers . current rating & type for fuses .
- RCDs . by Visual Inspection& Test . ◄◄◄
The effectiveness of automaticdisconnection of supply by RCDs shall be verified using ( Suitable Test Equipment ) according to ( BS-EN-61557-6 ) . see Regulation 612.1.
To confirm that the relevant requirements in Chapter 41 are Met .
The disconnection times required by Chapter41 . shall be Verified .
Re: ***Cont../ Useful Information for Electricians’ & Apprentices***
hi im just starting my 2392 10, i have a question . IDENTIFY IN ORDER TO PRODUCE A DESIGN SPECIFICATION THE INFORMATION REQUIRED FROM THE (a) CLIENT
(b) electricity distrubution network operator (DNO)
COULD YOU GIVE US A PUSH IN THE RIGHT DIRECTION TA
-&-s 2391-10 / 2392-10 . Inspection & Testing &Verification of Electrical Installation(s)
Required to be Aware of .
HASAWA . 1974 – Statutorydocument )
EAWR . 1989 – Statutory document )
BS-7671:2008 / 2011 – Non Statutory document )
O.S.G. – Non Statutorydocument )
Guidance Note 3 – Non Statutory document )
GS-38 – Non Statutory document )
Certificate is used for ( NewInstallations ) whenever a New circuit has to be Installed . & /or Alternations . Rewiring & anycircuit where the protective device has been changed .
As part of the (Initial Verification ) the date for the next Inspection must be set ( maximum 10 Years for Domestic Installation )
Certification & Reporting
This form must be Accompanied by ( Inspection Schedules& Test Results Schedules )
In the case of ( Consumer’s Unit change only ) Electrical Installation Certificate would be required for the ( Consumer’sUnit ) &
an Electrical Installation Condition Report ( EICR ) should be completed for the ( ExistingInstallation )
Minor Electrical Installations Work Certificate .
□ This one isUsed for work which ( Does ) not involve theInstallation of a ( New Circuit )
□ This Certificateis to be Used when ( Additions to Existing circuitsare carried out ) if .
□ More than Onecircuit is added . Then a separate - Minor Works Certificate . must be issuedfor ( EachModification )
ElectricalInstallations ConditionReport . ( EICR )
Your reasons . for this type of Test are . Wear & Tear . Change of Ownership . Change of Use . Damage to the Property.
This form must be Accompanied by ( InspectionSchedule & Test Results Schedule(s)
□ Diagrams .Charts or Tables should be made available to the person carrying out thisReport .
These Diagrams .Charts or Tables should indicate : Type of circuits & Protective devices .means of Isolation & Switching . methods used for Protect against Fault Protection .
Delegate . will be required to complete the AppropriateDocument during & after the Testing is carried out . ( Starting from . 01.01.2011 . this Documentwill be the ElectricalInstallations ConditionReport . ( EICR )
2392-10 : Weneed to Inspect & Test Electrical Installations to ensure compliance withBS-7671 :2011 .( Non Statutory document )
2392-10 : Bycomplying with BS-7671 :2011 . We arealso complying with HASAWA - 1974 & EAWR - 1989 Both ( Statutorydocument )
-&-s point of View 2392-10 . Insulation Résistance Measurement . (Measurement of Insulation Résistance are to be carried out before the first connection of Main Voltage to the Installation ) …D.C. test voltage .
2392-10 .
Take from BS-7671:2011 . -&-s .
( T ) Which of thefollowing items should be ( Included ) forchecking during the ( Initial Verification ) of an Installation .
Presence of diagrams & Instructions . ( Regulation611.3. (xvi ) Presence of diagrams . instructions &similar information . p/190
( T ) One ( Item ) that should be ( Included) on charts & diagrams made ( Available ) tothe person carrying out the ( Inspection & Test ) is .
All Isolation & Switching arrangements ( Regulation514.9.1. ( iii ) p/117 .
( T ) An ( Inspection ) shall be made to ( Verify) that the installed electrical equipment is . NotVisibly Damaged ( Regulation611.2. ( iii ) p/189 .
( iii ) – Routing of cables in Safe zones . or protection againstmechanical damage . in compliance with Section 522
( T ) Inspection & Testing . Continuity of CPC & Protective Earthing .
( You will use this on .Periodic Inspection & Testing )
p/Regulation 411.3.1.1. of BS-7671:2011 requiresthat Installations which provide protection against Electric Shock using Automatic Disconnectionof supply must have a circuit protective conductor run to & terminated ateach point in the wiring & at each accessory .
you are required to ( Verify the Polarity ) of all circuits before Connection to thesupply . Dead Test . 2392-10 . -&-s
2392-10 . youare expected to Energise the Installation & turning the supply on for thefirst time .
the Regulations don’t tell us about . Live Polarity . “ Testing “ . “ This is a Live Test
using a ( GS-38 ) approved voltage indicator . you are Testing on the Incoming side of theInstallation . MainSwitch .
Test between ( Line & Neutral )
Test between ( Line & CPC )
Test between ( Neutral & CPC )
After the correct “ Polarity “ has beenconfirmed . Turnthe Main Switch ON if Needed .
One Point I must make . Many Candidates failed to ( Identify the Used ofGS-38 . Test Leads ) ◄◄◄ -&-s Exams .
City & Guilds | 2391-301 Chief Examiners' report ( I wish someone HAD pointed meto the SITE before my 2391-10 ) Happy Hunting . :banghead:
2391-10 : Remember that giving information that is NOT required COSTS the CANDIDATE timebut does NOT ACCUMULATE any MARKS .
Brianmdk. Thank you for using this Forum . “ As arule you go into the Main Forum Q/As “
“ Old Amber “ . only writes up things for the Forum . . I am sure that Phil or any other Memberwill pick this up .
Has a rule I don’t. do Q/As . I leave that to the Professional Memberson this Forum . I will get in touch with Phil .
Brianmdk. am sure Phil has a ForumE/mail .
I get over 100 E/mail a day . So I limit my time when I can .
Example . -&-s . Correctly indentify the Three documents on which ( Ze) would be recorded .
This is how Ipicked up this . 2392-10 . Look in & start there . p/390 . EIC . ( Ze ) yeah . Minor / No . EICR / yeah . sometime we have to help ourselves .
2392-10 : Check – 530.3.4.which seems to require that the only protective devices specified by themanufacture can be used in a Consumer Unit .
Forinstallations with a 230V single-phase supply rated up to 100A that are underthe control of Ordinary Persons . Switchgear & Controlgear should ether :
-Comply with BS-EN-60439-3 & Regulation 432.1.of BS-7671:2011 .or
-be a Consumer Unit incorporating components complying with BS-EN-60439-3 .
2392-10: Check – 537.1.4.
Amain switch intended for operation by ordinary persons . e.g. of a household orsimilar installation . should interrupt both LiveConductors of a Single-phase supply .
531 . Fault Protection by Automatic Disconnectionof Supply . 2392-10 ( ADS )
531.2. RCD Requirements .–
531.2.1. An RCD shall be capable of disconnecting all ( Line Conductors ) at substantially the ( Same Time )
531.2.5. An RCD cannot be used for ( Fault Protection) on its Own . Where a circuit does “ NOT “ contain a ( Protective Conductor )
2392-10. Does an RCD . NEED an EARTH .
531.2.5. The use of an RCD associated with a circuitnormally expected to have a ( Protective Conductor ) shall NOT beconsidered sufficient for fault protection if there is ( NO such conductor ) even if the rated residual operating current ( IΔn ) of the device not exceed 30mA . … ►► RCD without ( Earth ) N/A
Taking off the Internet . ▼▼▼
RCDdoes NOT necessarily require an Earth connectionitself . ( it monitors only the Line& Neutral ) in addition it detects current flows to Earth even in equipmentwithout an Earth of it Own .
RCD- The amount of current flows through the Line should return through Neutral .
RCD– it Trip the circuit when there is ( Earth Fault Current ) .. Now it takes us back to Regulation ( 531.2.5. ) DO We NEED an Earth
RCD/ RCBO . “ Flying Lead “ has a Functional Earth
UsefulJunk . Example . 4D4Bp/339
1000 . is used in the formulabecause the value from the tables is in millivolts - Convert it to Volts .
Weknow the maximum voltage drop permissible is ( 11.5V) the current in the cable is ( 65A ) & the Length of run is ( 53m )
11.5x 1000 = 11500 .
(65A x 53m ) = 3445 . …………. 11500 ÷ 3445 = 3.33 mV
4D4B – for a Conductor whichhas a voltage drop of ( 3.33 m/V/m ) or less . 16mm[SUP]2 [/SUP]( 2.8 : 2.8 : 2.4 )
Noticethat for ( All ) cables ( Over ) 16mm[SUP]2 [/SUP]there are Threevalues given for voltage drop . ( r . x . & z . )
Requirements. Earthing & Bonding .
Often. there is great confusion over Earthing . Bonding ( Earth Bonding) BS-7671:2011 . requirements forElectrical Installations – “ Defines “
“Earthing “ Connection of the ( Exposed – Conductive – Parts ) of an Installation to the main earthingterminal of that Installation
Bonding “ Thecorrect “ title“ is “ p/27 . EquipotentialBondingelectrical connection maintaining various Equipotential Bonding & ( Exposed – Conductive – Parts ) & ( Extraneous – Conductive – Parts ) at substantiallythe same potential .
►►See also . “ Protective Equipotential Bonding “ p/32. “ Equipotential Bondingfor the purposes of Safety
(Extraneous – Conductive – Parts ) a “Conductive Part “ . liable to introduce a ( Potential ) generally earth (Potential ) & not forming part of the electrical installation .
(Exposed – Conductive – Parts ) a “Conductive Part “ of equipment which can be touched & which is not a Livepart but which may become Live under fault conditions
Just a Reminder . 411.3.1.2. Protective Equipotential Bonding .
Ineach installation ( Main Protective Bonding Conductor’s ) complying withChapter 54 . shall connect to the ( Main EarthingTerminal ) Extraneous – conductive - Parts . including . ( Water Installation pipes : Gas Installation pipes : Exposed Metallic Structural parts of theBuilding : e.g.
Requirementsof the Earthing System .
Thefunction of the earthing system isTwo-Fold .
□ To provide a low enough impedance path . viathe earth conductors . back to the supply source so that the event of a failureto earth of a live conductor . sufficient current will flow safety along apredetermined route to enable the (Circuit Protective device to operate )
□ To limit the ( Potential rise ) on allMetalwork to which persons & livestock normally have access . To a safevalue under normal & abnormal circuit conditions .
Thebonding together of all normally ( Exposed metalwork ) such . As Gas . Water . etc . & the connection of the ( Bond ) to the Earth Terminal . will prevent thepossibility of a ( Potential difference) arising between adjoining pipework under both normal & abnormalconditions .
Thereare Two main types of Earth Conductors . which are “ Bonding “ referred to as ( Protective ) conductor(s) & Earth Electrodes .
p/23 . Bonding Conductor : A protective conductor providing EquipotentialBonding .
Equipotential Bonding – Main Protective Bonding Conductor .
□The bonding together of all normally ( Exposed Metalwork ) such . As Gas . Water . etc .
p/37 . Main Metallic Water Pipe – ( Extraneous – Conductive – Part - p/28 )
Bonding& Protective Conductors .
Withinthe Regulations . a number of “ Definitions“ you have to describe the differenttypes of earth conductor used .
CircuitProtective Conductor ( CPC )
Thisis a separate conductor installed with each ( Circuit ) & is present toensure that some . or all . of the ( Earth Fault Current ) will flow back tosource along it .
Itmay be an ( Individual ) conductor . the ( Metal Outer Sheath of a Cable ) or ( Metalwork formed by Conduit or Trunking )
p/23 Bonding Conductor(s) . A Protective Conductor providing : Equipotential Bonding p/37 . MainProtective Bonding Conductor .
Theseensure that ( Exposed – Conductive –Parts ) such as Metal Enclosures . remain at approximately the ( Same Potential) e.g. Under Fault Conditions .
p/27 .Exposed – Conductive – Part . Conductive part of equipment which can betouched & which is not normally live . but which can become live . UnderFault Conditions .
►The two forms of “ Bonding Conductors“
p/37. • EquipotentialBonding is Main Protective Bonding Conductor .
whichinterconnect ( Together ) & to Earth . ( Exposed – Conductive – Parts )which do NOT normally carry current . “ But “ could do so under a FaultCondition .
these( bonds ) normally connect Exposed –Incoming Metal – Gas . & Water pipes……. Main Services . to the ( EarthingSystem )
asit was on the 16[SUP]th[/SUP] Edition . & is still in Use today .
SupplementaryBonding Conductor(s)
Toensure that Electrical Equipment & other items of ( Conductive – Material )in specific ( Zones ) are bonded tighter & remain at ( Substantially the same Potential )
Theyare used in ( Addition to the Main Protective Bonding Conductor . & (Circuit Protective Conductor )
EarthElectrodes . designer . is faced withTwo – Tasks .
□ To ( Achieve ) a required Impedance Value .
□ To ( Ensure ) that “ Touch Voltage “ potentials are satisfactory . 50V .
(TT System ) for most if NOT all of this “ Site “ You do this by NOTusing the DNO – Earth . you provide a ( Rod )
Therisk of Electric Shock is high .
TN-C-Ssystems must not be used forConstruction & Demolition sites Supplies .
TN-C-S supply is provided by the supply provider . ( PS .use your own judgment ) No in the regulations. it may be Converted to a ( TT System this is easily achieved by isolating the supply earth fromthe installation & installing an Earth Electrode for use with an RCD – 500mA
(110V – for all portable ( Tools & Lighting ) 0.2 seconds disconnection for fixedfloodlights ) Table 41.1. 230V – TT – 0.2 seconds.
(230V – Single-phase ) 0.4s & 5s .
TestingEarth Electrode(s) . Pulled out oldNotes . So that got me Started . !! Books are Out .
Ifa 30mA RCD is used . this allows a maximum Electrode Résistance of ( 1.667Ω) although it is recommended that earth electrode résistance should never begreater than ( 200Ω ) A maximum valueof ( 100Ω) is proposed in a draft amendmentof BS-7430 . Code of practice forEarthing .
BS-7430:1991 – which is withdrawn .
Guidanceon the Methods for Earthing Electrical Systems
Abstracts BSI BS-7430: 1991which is withdrawn.
Givesguidance on the methods that be adopted to ( Earth ) an Electrical System forthe purpose of ( ►► Limiting thePotential ) with respect to General Mass ofEarth . of current – carrying – conductors ( Forming part of the System) & ( Metalwork associated withEquipment . Apparatus . & Appliances connected to the System )
TheElectrical Supply . 16[SUP]th[/SUP] Edition
Thefollowing electrical systems are NOT suitablefor use in hazardous locations .
TN-C.
TN-C-S. ( PME )
InTN-C & TN-C-S - ( PME ) supplies . the Neutral conductor is also the Earthingconductor . Therefore . there could be a ( PotentialDifference ) between the main earthing terminal of the Installation& the General mass of Earth .
This( Standard ) applies ( Only) to landbasedInstallations .
BS-7375:2010 . Distribution on Construction& Demolition Sites . Code of Practice .
Whatkinds of sites are covered by BS-7375 . BS- p/214.
Thesites covered in this standard are areas where any of the following take place.
• Construction work of new buildings
• Repair . alteration . extension . demolitionof existing buildings or part of existing buildings .
• Engineering works .
• Earthworks .
• Work of similar nature .
-This requirements apply to ( Fixed ) or ( Movable Installations )
Updatingof references to BS-7671 . take into account the publication of the seventeenthedition.
704.411.3.1. – Protective measure . Automaticdisconnection of supply .
A( PME ) earthing facility shall NOT be used for the means of earthing for aninstallation falling within the scope of this section ( Unless ) all Extraneous – Conductive – Parts . are reliablyconnected to the main earthing terminal in accordance with Regulation – 411.3.1.2.
Justa Reminder . 411.3.1.2. Protective Equipotential Bonding .
In each installation ( MainProtective Bonding Conductor’s ) complying with Chapter 54 . shall connect tothe ( Main Earthing Terminal ) Extraneous – conductive - Parts . including . ( WaterInstallation pipes : Gas Installationpipes : Exposed Metallic Structuralparts of the Building : e.g.
Thereare differences between BS-7375 & BS-7671 . to do with ( Disconnection Times )
Thereis a large Overlap with BS-7671 . section 704 . different approach in ( BS-7375 ) particularly on the ( 110 volt system) 55 voltsto Earth .
Note . if a ( PME ) Earthing facility is ( Considered) for Use . see also . p/280 - BS-7375:2010 . 704.0./ 704.411.3.1.Note
(p/54 - Disconnection Times ) 411.3.2.3. in a (TN- system ) a disconnection time Not exceeding ( 5s ) ispermitted for a distribution circuit & for a circuit NOT covered by Regulation . 411.3.2.2.
(p/54 - Disconnection Times ) 411.3.2.4. as Appropriate . in a (TT – System ) a disconnection time Not exceeding( 1s ) is permitted for a distribution circuit& for a circuit NOT covered by Regulation . 411.3.2.2.
( Disconnection Times ) for reduced – Low – voltage –systems in BS-7671 & see if you canfind any ( Equivalent in BS- 7375 )
Classificationof Tools .
Class1 ) tool having at least ( Basic Insulation ) throughout & under certain conditionsrequired to be Earthed . BS-EN.61140. P/287 .
Class11 ) tool with ( Double Insulation ) & / or reinforced insulation throughout& without provision for Earthing . BS-EN.61140.
Class111 ) tool designed for operatingat ( Safety Extra Low Voltage ) BS-EN.61140.
Safety Extra Low Voltage ( SELV ) (- Nominal voltage not Exceeding 50Vbetween conductors . & between conductors & earth . No-load voltagenot ( Exceeding 50V )
704.410.3.10.
Note 1 : The reduced low voltage system is strongly preferred forthe supply to portable hand lamps for general use portable hand tools &local lighting up ( 2kW )
Note 2 : The ( SELV ) system is ( Strongly) preferred for portablehand lamps in ( Confined ) or damp locations .
BS-EN- 60947-2 . MCCBs areadjustable – Thermal & Magnetic tripping characteristics . can be changedon the device . ( normally have to beObtained from the relevant Manufacturer )
RCDsmust conform to ( BS-4293 still on Old Sites )BS-EN- 61008 or 61009 .
OnExisting Installations . ( Integrity ofCables )
p/17. Regulation 131.2.2. 2392-10 .
Goeson to confirm that . in connection with Fault Protection . the application ofthe method of ( ProtectiveEquipotential Bonding ) is ONE of the important Principles for Safety .
Copperhas & continues to be the most widely used material for Earthing .
BS-7430. Code of Practice for Earthing .
Whichstates “ Copper is one of the better & commonly used materials for EarthElectrodes & Underground Conductor’s .
Earthingarrangements’ within buildings in the UK . should conform to BritishStandard – 7671: & 2011.
Forthe sake off . 2391-10 . -&-s Exams . The requirements for “ Erection & Initial Verification of Electrical Installations .
(2 sets of Testing here ) Verification &Periodic Inspection & Testing
i) InitialVerification . 134.2.
ii) Periodic Inspection . 135 . – tofollow 134.2.2.
Appendix 6 . for Certification & Reporting Electrical Installation ConditionReport . that replaces the ( Periodic Inspection Report ) New condition reportincludes a New Inspection Schedule
p/36. Verification : All measures by means of which compliance ofthe Electrical Installation with therelevant requirements of BS-7671 are checked . Comprising
Inspection. Testing & Certification .
134.1.7. Testing – Where necessary for safety purpose. suitable warning signs & / or notices shall be provided .
BS-7671:2011 & GN-3 . go Hand & hand . intesting . & Exams 2391-10 .
313.1. Reminds us . (v) The suitability for the requirements of theinstallation . including the Maximum Demand . 2392-10 .
MaximumDemand . Ring Final Circuit – maximumpermitted sustained load to be drawn by this circuit would . be 32A – 100%
Doesthe device that has to be provided for switching off a bathroom ( Extract Fan ) for mechanical maintenance need to be locatedadjacent to the Fan . ( No )
p/152. Regulation – 537.3.2.4.
Butthe device does need to be placed & marked as to be readily identifiable& convenient for the Intended Use .
2392-10: Installation Circuit Arrangements .
p/46. The Four Regulations under Section 314 of BS-7671:2011 .
Setout the requirements for the circuit arrangements . Essentially . circuits mustbe provided in sufficient number so that danger is prevented . &inconvenience minimised . both under normal & fault conditions &arranged so that operation . Inspection . Maintenance & testing may becarried out in a safe manner .
Itis Important . that a sufficient number of circuits are provided so thatequipment unaffected by a fault condition remains safe & functioning whenanother circuit develops a fault . The designer would need to consider theeffects . in terms of consequential events . of the operation of a singleprotective device .
Regulation314.1.4. calls for each circuit to beelectrical separate & connected individually & detached from all othercircuits where they terminate in a distribution board .
Implicitly: the connection of each circuit Line .Neutral & CPC conductors must follow a logical sequence at theirtermination in the distribution board
Summaryof ( Low
ExistingBS-7671:
Summaryof ( Low – voltage ) fuse standardchanges for first amendment . p/295 .
ExistingBS-7671:2008 fuse. BS-88.2.2. : BS-7671:2011 fuse . BS-88-2 . ( Bolted ) type fuse is recognised ( Fusesystem E )
ExistingBS-7671:2008 fuse. BS-88-6 : BS-7671:2011 fuse . BS-88-2 . “ ( Clip in ) type fuse is recognised ( Fusesystem G )
ExistingBS-7671:2008 fuse. BS-1361 : BS-7671:2011 fuse . BS-88-3 . “ ( Cartridge ) type fuse is recognised ( Fusesystem C )
Ambient Temperature Correction Factor .
The measured Loop Impedance given . O.S.G. p/120 . Table B8
Thevalues assume that the maximum operating temperature of the insulation is ( 70°C ) & the Ambient Temperature whencarrying out the test is at ( 10°C ) AtAmbient Temperatures other than this . Correction Factors . should be applied .
Table B8 p/120 . The correction factor is given by :
(1 + 0.004 – ambient temp – 10 )
Where( 0.004 ) is the temperature coefficient per ( °C ) at 20°C for copper &aluminium .
If the ambient temp is ( 25°C - 1.06 ) the measured impedance of the circuit protected by a ( 32A type MCB ) should not exceed ( 1.16 x 1.06 = 1.23Ω )
SomethingKnock-up . 2392-10 .
□ Measurementof Prospective Fault Current - Ipf - ( PFC ) & ( PSCC )
For the sake of -&-s )- This test is made with an Earth Fault Loop Impedance Tester set to Amps . -&-s– BS-EN-611557-3.
The ( PFC ) which is how much current will flow in the event of a fault .
isdivided into two parts .
Prospective Earth Fault Current )- Line to Earth .
Prospective Short Circuit Current )- Fault between Liveconductors ! L/N
The ( PFC ) test is made at the Origin of theInstallation . & its value ( Obtained in kA )
(PFC ) & ( PSCC ) tests ( Higher ofthe Two Values is Recoded )
□ How do we Do this Test . for -&-s sake .
BS-EN-611557-3. – GN-3 ◄
AnEarth Fault Loop Impedance Tester .the valueof Earth Fault Loop Impedance ( Zs ) maybe determined by . !!
i) Direct measurement of ( Zs ) at thefurthest point in the circuit .
ii)Direct measurement of ( Ze ) at the Origin of the circuit &adding to the “ Value “ of ( R[SUP]1[/SUP]+ R[SUP]2[/SUP] ) point to NOTE : measured during Continuity Tests .
iii) Obtained the “ Value “ of ( Ze ) from theElectricity Supplier & adding to this “ Value “ of ( R[SUP]1[/SUP] + R[SUP]2[/SUP] ) as above .
(Ze ) is the Loop Impedance “ Value “ External to the Source of the Circuit(s) Supply .
□ DirectMeasurement of ( Zs )
Directmeasurement of Earth Fault LoopImpedance . is achieved by use of an . Earth Fault Loop Impedance Tester .
TheInstrument operates from the main supply & therefore can only be used ona ( LiveInstallation ) connected directlyto the ( Furthest Point ) of the circuit .
Note : ( Parallel Paths) will be present which will ( affect ) the true circuit(s) Earth Loop ImpedanceReading(s)
□ Measurementof ( Ze )
(Ze ) can be measured using an . Earth Fault Loop ImpedanceTester . at the ( Origin )
Connectedusing approved leads between the ( Live Terminals ) ofthe supply & means of Earthing with the main switch closed .
Note : to Remove the possibility of ( Parallel Paths) the means of Earthing must bedisconnected from the Main Protective Bonding . conductors for the duration of the Test.
“ Verification “ of Earth Loop Impedance Test Results .
Valuesof Earth Loop Impedance obtained ( Zs ) should be compared with one of thefollowing . 41.3.: 41.4. : 41.5. :
EarthFault Loop Impedance ( Zs )
This is a Live Test .
Canbe obtained direct measurement using an “ Earth Loop ImpedanceTester “ Or by adding ( R[SUP]1[/SUP] + R[SUP]2[/SUP] ) obtained earlier to ( Ze )
Obtaining( Ze ) External Loop Impedance .
ByEnquiry ( Must test to ensure Earth ispresent )
Direct measurement of ( Zs ) can only be made on a . Live Installation. No earthing conductors aredisconnected for this purposes of the test & this may result in readingsobtained which are lower than the value of . Ze + ( R[SUP]1[/SUP] + R[SUP]2[/SUP] ) This is due to the parallelearth paths presented within the installation .
□ Whattype of Earthing System are there .
Thereare Three types listed in BS-7671:2011 . p/45
TN-S. system
TN-C-S. ( PME ) system .
TT. System .
2392-10: Testing point of View .
Continuity of protective conductors is clearly important as are the Tests for ( Insulation Résistance : Loop Impedance : Operation of RCDs )
(1 ) -
InstantaneousTrip Currents . x In .
MCBs : Icu - ( rated ultimate / breaking capacity )
MCBs : Ics - ( rated service / breaking capacity )
Thedifference between . BS-EN-60898 MAY be used insteadof CALCULATION “ / BS-3871 formula. To beUsed :
BS-3871– are still out there .
MiniatureCircuit Breakers “ conforming to BS-EN-60898 are suitable for Isolation ◄
Miniaturecircuit breakers ( MCBs ) manufacturedto earlier standards . such as . BS-3871 : are unlikely to be suitable for Isolation. ◄
Note: There is NO type ( A) instantaneous tripping characteristic to ( Avoidconfusion ) with the ( A ) abbreviation for Amperes . B : C : D : - MCBS
Determinationof Maximum Earth – Loop Impedance ( Zs )
Themaximum value of Earth Fault Loop Impedance maybe found in the . Wiring Regulations . BS-7671:2011 . details’ published bythe Manufactures . ◄◄
B: C : D : - Table 41.3 . BS-EN-60898 . ( For instantaneous operation givingcompliance with the ( 0.4s ) Disconnection time )
B) 3 ( In) to 5 ( In )
C) 5 ( In) to 10 ( In )
D) 10 ( In) to 20 ( In )
B / Curve.
Themain characteristic of the ( B ) curve is Instantaneous trigger for currentsbetween ( 3 to 5 times) the rated current . Therefore .
Theyare mainly applied for the protection of circuits with ( resistive characteristics ) or involvingsignificant cable distance . Incandescent lamps . showers. . etc .
{ B means the fast magnetic trip will operatebetween ( 3 to 5 times ) nominal setting }
p/25 . Circuit Breaker. Abnormal currents such as Short Circuit Currents}
Note : THE valuesspecified in Table 41.3. for the types& ratings of Overcurrent devices listed “ MAY be used insteadof CALCULATIONp/55 . ◄◄◄◄
Circuitbreakers are going to be used for protection . disconnection times willautomatic conform to the requirements provided that the circuit(s) meet the ( Zs ) …. 41.3.
MCBs. BS-EN -60898 .
TypeB – 3 & 5 times . its rating passed through it .
TypeC – 5 & 10 times .
TypeD – 10 & 20 times .
Tablesfor ( Zs ) specific value of current is required . ( Worst case is Used )
OhmsLaw : to the supply voltage ( 230V ) & ( Ia ) to obtain a ( Zs) value for the device . Regulation411.4.5. – ( Zs x Ia ≤ Uo )
TypeB . – Zs for a 20A can be calculated . 5x 20 = 100 . 230 ÷ 100 = 2.3Ω …… ( Worst case is Used ) ◄◄◄
TypeC . – Zs for a 20A can be calculated . 10 x 20 = 200 . 230 ÷ 200 =1.15Ω
TypeD . – Zs for a 20A can be calculated . 20 x 20 = 400 . 230 ÷ 400 =0.57Ω
Switch disconnectors. it function is Only to disconnect electrical circuits with currents of up to 100A . Singlepole . “ Doublepole “ . Triple pole . Four pole .
MainLoad Disconnector Switch – Isolator .
(2 )
Regulations’. table 41.3 . ( Look it UP )◄◄
Rating20A – Zs . is 2.30Ω .
TypeC . – Zs for a 20A can be calculated . 10 x 20 = 200 . 230 ÷ 200 = 1.15Ω
TypeD . – Zs for a 20A can be calculated . 20 x 20 = 400 . 230 ÷ 400 = 0.57Ω
***Cont../ Useful Information for Electricians & Apprentices***
Australia
amberleaf,
Dan,
