Hello all,
I have just done a pre-works visit for a CU change and found continuity between neutral and earth!!
This is a TT so I didn't think I needed to disconnect the main earth but after getting continuity between N-E I did, I also disconnected main bonding but still getting N-E continuity. Main switch is open.
There is an voltage operated earth leakage circuit breaker and I had disconnected the earth link to the CU from this.
I've looked through past threads rather than just posting up but all I can see is advice about TNCS.
Am I overlooking something simple? I hope so but I suspect I have a fault?
