Discuss Continuity Tests in the UK Electrical Forum area at ElectriciansForums.net
P
PLW
Is the continuity test for circuit protective conductors, the same test for ring and radial circuits or is there a different test for each type of circuit?
Also what is the difference between testing for cpc continuity and testing for continuity for ring final circuit conductors?
Relocated from Trainee application forum.
There's already a similar thread running so I'm closing this one.
Reply to Continuity Tests in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
