Discuss Critical Feedback recent Consumer unit install Please. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I would like to know how I could improve on this board. All opinions
50047
welcome.
Agree with above, it would be good to have a service loop of slack in the CPCs, as there is in the L & N. If one of the top circuits in the earth bar needs reterminating after it has been removed for testing or rearrangement of circuits following an alteration, there's hardly any slack available.
Heat shrink earth on the box earth. Shorten the earths in the terminals so they are not all poking out on the other side of the terminal. There is one neutral fly lead from the RCBO around the middle that looks like it needs moving up slightly in the terminal. The T&E coming through the back should have been stripped using an electricians knife not ripping out the earth. Cut off the unused bus bar live unless there are more RCBO's to go on. I assume the bus bar (live) cover is going to go on when you are finished? I would try to achieve a straighter line on the neutral fly leads from the RCBO's rather than them all sweeping in as they do. Apart from that lovely!
That's seriously tidy work, the only thing I'd think about is whether the CU back openings on a wooden board could compromise the fire enclosure. It's a grey area but if it were in my house I'd want any material completing the enclosure to have a reasonable fire rating.
There's some chat about it on the voltimum site here. In reality it's unlikely ever to be an issue, but worth a thought.
Is it just me...or is the bus bar at the bottom awfully close to the base of the consumers unit
It almost looks like it is touching or at best a smoke paper away from touching
Why 2 separate feeds?
Is it all on 1 phase?
The main problem you have is the very poor lay out of the panel..
You would have done better yourself building one from scratch..
Reply to Critical Feedback recent Consumer unit install Please. in the UK Electrical Forum area at ElectriciansForums.net
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
