Discuss CU with a problematic RCD in the UK Electrical Forum area at ElectriciansForums.net
SJD
Mentor
Went to look at a consumer unit this evening, the owner is having trouble with the RCD not working, notice anything odd about the installation?
busbar gives it away. all breakers are fed direct from main switch and looks like RCD L on both in and out is connected direcly to main switch Lout. .
obviously B&Q need to update the you can do it manual. or is that what you get when you accept the lowest quote?
Yes, RCD L in and out are indeed both connected to main switch L out.
The owner has already had 2 electricians visit, one said the CU needed a new RCD fitting, other other said it needed completely rewiring ...
yep, first miss piggy, followed by statler and waldorf. or was it curly, larry and mo.
Reply to CU with a problematic RCD in the UK Electrical Forum area at ElectriciansForums.net
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Hello, I was looking at installing a SPD into an existing split load RCD BG consumer unit. In the instructions for the SPD it states that it may...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
