Baddegg
Supporter
Patron
Need to move a CU up approx 9 inches.....was thinking din rail enclosure with wagos, never done it before so was after some recommendations and advice ?
neater to use din rail connector blocks. here's one i did.
Whatever box and connectors your preferred wholesaler has on the shelf is usually easiest.
You can get plastic boxes which come packaged with suitable din rail or else just get any adaptable box and fit your own rail.
Thanks Dave, started using TLC now and they seem to stock everything, spoilt for choice!
Baddegg
Supporter
Patron
Southsea
United Kingdom
If other, please explain
Din rail enclosure recommendations
Baddegg,
pirate,
