Discuss disconnection time permitted for protective devices? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If you have a copy of BS7671 regs your answer is on pages 46 to 50 if not waht system do you have ie TT TNCS TNS and do you have fuses or RCD/MCBs
Chris
Normally 0.4 seconds for domestic circuits and 5 seconds for distribution if I remember correctly
Chris
As above, but the 5s disconnection time depends on the installation method of the distribution circuit.
Also, TT systems disconnection times are lower.
and because of that, osg says generally to achieve the disconnection times, EVERY circuit must be protected by an RCD, in one form or another...on a TT system
Reply to disconnection time permitted for protective devices? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I’m interested to hear other views on BS3871 MCBs being changed following a C2 non compliance on an EICR for over rated protective device. Eg...
I would like to get some information on what protection is on a multi meter when accidentally testing a live circuit while the meter is on the...
Bathroom with an electric shower wired to the latest regs with a 40A MCB and RCD protection. Is the disconnection time 0.4s or 5s. Looking at the...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
