Discuss earth fault loop three methods? in the UK Electrical Forum area at ElectriciansForums.net
when confirming auto disconnect of the supply it is necessary to determine the external earth fault loop impendance of the system. What three methods can this be achieved?
So the external earth what loop impendance is the supply companies end is that right?
Correction Answer 3; Not guess, but ask on a forum and take the majority answer.
but he needs the answer NOW< not after 395 posts, some of which would be calling his parenthood into dispute.
Reply to earth fault loop three methods? in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I'm new to Amtech/Trimble and I've been asked to review a model. I'm looking at circuits that are SWA cables using the armour and an...
Hi all I don't appear to be able to post in the DIY forum so apologies if this is the wrong place. I live in a block of flats with an external...
I have a box powering three 3-phase motors off of one 240V single phase line, NEMA 10-30. In the picture you can see a wiring diagram. The...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Two related questions in 1, if anyone is up for helping! (i) When electricians install supplies, is there anything in the regs that says how many...
