polo1
....on a property rewired approx three years ago with no local isolation for the electric oven (using the cooker circuit) - Code 2 or 3?
Regards.
I do not believe BS7671 specifies a cooker must have a local isolator.
I would mention this in the covering letter or as a non coded observation.
I like local dp isolation, but don't think you can code it. Is it table 3 that states you can use the circuit breaker as means of isolation.?
Tbh, I was being a bit lazy in asking the question here, as my byb is in the hands of another. I was/am having brain fade on this. I know there is mention of local & remote isolation, but couldn't recall if isolation beyond the mcb is an actual requirement. I'm suitably embarrassed
Don't worry about it Polo, we are all here to help each other, My memory is rubbish can't remember what I done yesterday.lol
I think if you check with the manufacturer you will find it requires a local DP switch.
Fortunately, we no longer have to comply with manufacturer's instructions, just take account of them.
If the equipment or whatever broke down, caught fire whatever the manufacturer would certainly turn around and say "well you did not follow our instructions regards installation so we cant help"
Yeah and I guess trading standards and a judge will be quite happy with that.
Tell me, my oven with it's 3 pin plug, where exactly is the DP isolator supposed to go?
LOL. It's debateable whether that is really any different. If you "take account" of the instructions you might need good reason to then dismiss them.
I would be very carefull with that attitude, if an items fails and causes damage and manucarurers instructions have not been followed you are then liable.. extractor fans are prime example of this not being fused down to 3 amp. Ive read of instances where fires caused by extractor fans, the spark not fused down and then liable.
You have to remember that the majority of these are just the manufacturer desperately looking for a way out of paying.
For instance the change from a 6A MCB to a 3A fuse will make very little difference in the majority of faults, the "stalled" current of an extractor fan is unlikely to reach 6A and a short circuit will be in hundreds of amps and disconnect instantly either way. The fault current would have to be between 6 and 18A to make a difference and this is unlikely.
If an item has been installed professionally and safely there is little the manufacturer can really do in most cases, except try it on and succeed.
