Discuss electrical installation on a floating dwelling in the UK Electrical Forum area at ElectriciansForums.net
Andy78
Mentor
I really need some help in a project I have become involved in wiring a lived on boat. It's something I have not done before or anything remotely similar so I'm well out of my comfort and confidence zone.
I'm really struggling finding a definite guide as to the correct regulations I need to be following or even any best practice guides. If anyone can offer any experienced advice in this field I would be most grateful, even a finger pointing in the right direction would be great.
I'll refrain from posting detailed info about the job until an experienced mind pops along as it might be a bit much.
The installation on the boat is nothing special- just to bs7671
As long as it’s connected to a supply conforming to section 709, marinas and similar locations.
Section 709 shows the supply cable on the boat, and special regards to metal parts in contact with water.
I think you have to carefull that you dont connect the metal hull to earth as it can course corosion i think , sorry to be vage on it but i remember it being talked about back when i was in college , worth looking into.
Ok, bit more info.
Won't be connected to a shore hook up, but will have the capability to be.
Boat is a steel hull
Will be powered via solar panels charging 12V batteries.
12V and/or 230V (via inverter) will be used for lighting and power with a 24V system for the engine room solely for the engine start operation.
Yes, have heard about galvanic isolators needed when hooked up to shore supplies, need to research this a bit more....
If its a canal barge, you take it on the right hand side, and not the left when "driving" it along.
I took a family members boat along the Union Canal in Edinburgh from the centre out to the bypass. There's an aquaduct crosses the 4 lanes of the bypass... my kids on the bow waving at the drivers below.
Only thing we had to watch out for was the university canoe club.
The Union Canal needs a good dredging. One time I wasn't there, the boat picked up an old mattress from the bottom and wrecked the propellers. A week later another boat brought up a corpse. :eek:
If a steel hull there are some caveats, however as the majority of the installation is 12V or 24v then you are simply providing shore power, perhaps from a marina supply?
If you are only providing a supply for charging the battery bank, the job is easy. If you are providing a mains supply for heaters/microwave/lighting, then you have a double-double insulation task, especially in a metal hull.
Don't be miss-led by the anodes bolted to the hull to protect against corrosion. You need to keep the shore power completely isolated, as if you were running a heater off an extension lead.
It's an interesting problem, but not needing over-thinking. Hardly anyone dies linking a boat to the marina supply with a commando plug...like a caravan, but with a bit of a twist?
just treat it like a mobile home .
The idea is to generate all power to charge the 12V batteries from solar panels. No available shore hook up at the mooring location. Inverter will be present to provide 230V for a fridge and telly, possibly games console too for the kids.
I think I am over thinking it a bit maybe but was already thinking along the lines of a double insulated system.
Reply to electrical installation on a floating dwelling in the UK Electrical Forum area at ElectriciansForums.net
Guidance please - C&G L3 electrical installation - Hotel extension project Hi folks, I am fairly new to this forum but it looks like the...
Hi, I've recently had my broken oven replaced in my flat and I paid for delivery and installation. It was hardwired through an unswitched plate...
Hi all. In a bit of a situation which is starting to cause a fair bit of stress and figured maybe asking some silly questions here may help to...
