@Midwest I’m hoping that’s a serious question?
You should know that Plasterboard will provide a degree of fire protection. A single sheet of 12.5mm Gyproc is estimated to deliver up to 30 Minutes of fire resistance BUT when standard domestic house plans are made there is no inter-floor fire resistance requirement.
Why not? Just stand at the bottom of your stairs and estimate the fire delaying characteristics of that 13-step chimney!
So there’s no practical reason to stop up downlight holes with intumescent materials.
If the ceiling IS a fire barrier
See
What is the fire resistance performance of Gyproc plasterboard - https://www.british-gypsum.com/technical-advice/faqs/050-what-is-the-fire-resistance-performance-of-gyproc-plasterboard
Then the integrity must be maintained, but not unless it is a fire compartment that has been compromised.
You may way to take a risk assessment and say, it’s my daughters room above the kitchen so I want fire-rated fittings. It’s up to you. My choice would be to plan how I get her from her bedroom and out of the house, when the stairs are on fire.[/QUOTE]
Last time I checked all rooms leading to my stair case have doors; albeit not fire doors but would go some way to negate the spread of fires. That's why you should close them at night, before retiring to bed. Surely you'll see the fire safety videos, to know that.
We also required to reinstate any holes we make in the structure of a domestic building, to the same level of fire protection as previously, to prevent the spread of fire. As I was alluding to, one of the reasons for using plasterboard, is to prevent the premature failure of structural timbers. Its also why non metallic cable clips, can be used above etc etc. So cutting large holes into plasterboard, and leaving them, would stop this simple system from functioning.
Of course there are specific building regulations to fire safety, but this does not exclude good practice.
Electrical Safety First Best Practise Guide 5 is an interesting read, and may be useful to the OP;
Best Practice Guides - https://www.----------------------------/electrical-professionals/best-practice-guides/
