Are you trying to tell me BS5266 makes no reference to lux levels?
no , i'm saying it doesnt request lux tests to be carried out during annual testing once the system is in service - read my statement that you just quoted again.
it also recommends standard lighting remain functional during testing as was pointed out many many posts ago by another poster.
depends on how the circuit is set up
emergency lights seperate circuit/switch wire
or all together - loop from key to l/sw so the key is master and the l/sw operates as normal until key put into power cut mode
It says the lights have to be bright enough.
You can prove they're bright enough with a tester which tests how bright they are.
Well apparently it's not obvious enough, hence why I've had to say the same thing several times.
and each time i've pointed out that youre not required by offical guidance to do the measurement you say needs to be carried out but you just wont listen.
