A
Ashley Poxon
Installed 3 new circuits in a 3 phase board all emergency and on key switches, the not em's will work with the key switches off. Turn a key switch on and the circuit trips, turn the next key switch on and that one will trip but if you reset the breakers and do the 3rd key switch it trips two circuits. I'm thinking it's something simple- I didn't do the dead nor live testing but if he's done it correctly then it passed. I was thinking maybe neutrals mixed up but it's not a split load board. The circuits are on rcbo's so could it be the ballasts? Wouldn't say loading as its only 7 fittings per circuit at around 4amps per 6A breaker. Any ideas
