L
legacy
I wonder if anyone can advise what might be the best method to check if an electricty supply coming in, has either a leak or a faulty meter that results in high usage of units being charged? Would you suggest a load test or 2nd "check" meter to be installed?
We installed 3 Phase into a domestic property approx 6000 sq ft, installed an air source heat system to provide economical heat but have seen a dramatic increase in electricty charges since the installation that now run into 40,107 units per Qtr being charged, around £5000 per Qtr for a family of 5, seems an incredible amount of units for a general household.
Energy providers are not helpful to seek the fault, despite monitoring usage from independant monitors I have installed, it confirms the units being used but cannot believe a general docestic dwelling can use this much? particularly in the summer with no heating appliance on?
Any suggestion what could be the next step to have this checked or how to go about it?
