Discuss Fans, fuses and isolators in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
So I've been to see a broken fan requirement...... in a park home.
No isolator, no access to cabling, no loft...
So how the hell can you install to manufacturers requirements???
Discuss....
a park home? you talking about a caravan park?
If so, ive got the same current problem at the moment. Replacing a fan, yet your supposed to wire to manufactures instructions and its literally not possible. Been stalling the job for a week now.
Install it cash in hand with no MWC so theres no trace you've ever been there if anything goes wrong? :38: jokes...
What im thinking of doing, is patching the old fan up and taking 3core from the light too a newly installed isolator then wire a fan next to the isolator. Then getting someone to patch the hole up where the old fan was, and dragging the cables out...if possible.
They are the "modular" type homes on wheels, bolted together so wider than caravans. The supply is 2 core so no timer/overrun - a right pain.
I might just call Elecsa and see what they say!
The static lodges that are bolted together on the pitch (come in 2seperate halves) ??
Some of them models ive worked on do have a loft space...that stewart little would have difficulty getting into. I feel your pain Murdoch.
Fan's are always a pain in statics. Can you not do what im gonna attempt, move the fan to a new posistion and try fish the wires accross the ceiling? They are hollow enough, just can take ages tryna grab them when you can't see F all.
Reply to Fans, fuses and isolators in the UK Electrical Forum area at ElectriciansForums.net
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Evening, I've been asked to install a supply to a sprinkler system in a new installation that must be separate to the building electrical...
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
