Discuss faulty ring main in the Australia area at ElectriciansForums.net
daniel hill
hi all
have a small problem
there is no continuity on the blackl
i have droped all the fronts of and all connections are tight
check all the jb and all connections are tight
i dont no what else to do
i possibley think it is a broken wire(ovious i no) or connectors in the wall and just bin plasterd over possibley as have come across it before
how would i test this to find it just megger the lega and if no continewity bingo that the faulty wire
cheers lads n ladies
danny
Best way to trace where the break has occured is to split the ring in half. Your continuity readings from that point will show you which side of the ring the break is on (hopefully there`ll be just one) & then just work back towards the CU from there.
Reply to faulty ring main in the Australia area at ElectriciansForums.net
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
I have come to extend a ring main on the old wiring (red and black) and have used the wago 222 connectors to extend each leg and extended each leg...
4K
Hey there, Sorry I’ve just joined up. I’m a qualified electrician/Electrical engineer. Recently sat my 2391-52. My question is I had a fault...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
