Discuss Fire Alarm Remote Indicators in the UK Electrical Forum area at ElectriciansForums.net
They are handy to have so you know which device has been activated, assuming this is not an addressable system. They also help routine testing as it indicates where the devices are. Void detection should be on the same zone as the room/area below.
The fire service will read the panel as loft, void on which ever area, if there is any confusion or ambiguity to the location then to be agreed with BC and the local fire service to whether remote indicators are necessary.. it is dependent on the application, if you have say 10 in a loft or void in a large area then yes local remote indicators should be fitted, if however you can identify a small room and the panel will identify it as the void above then it may be acceptable to omit the need. It is BC and fire service subjective view and may differ county to county.
If in doubt fit them as I always do, given that BC znd the loca fire brigade will no longer accept any design liability regardless if they instruct it it is best to go belt and braces.
Reply to Fire Alarm Remote Indicators in the UK Electrical Forum area at ElectriciansForums.net
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
Now there's a requirement for a Fire detection in all bedrooms as well as hallways Lounge and Kitchens can the detectors be wired from the...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
