Discuss Fire proof clips / cleats for SWA in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Look at Linian. Their fire rated clips look smart for such a job, assuming straight into brick. They are not particularly cheap - dep on wholesaler.
have you thought about tray or uni strut with lid? i think tray and one cable can be as quicker to fit as you need less fixings into the wall then just cable tie with the odd stainless tie incase of fite
Reply to Fire proof clips / cleats for SWA in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
