O
Octopus
Got an extension to fit down lights into - can anyone please point me in the direction of the latest regs and guidance regarding this thorny issue
We all know that downlights are available to be installed with insulation covering I don't think that you will be able to fit one with remote LED driver as it burns them out .How much of the insulation would you have to cut away?.I think that you will have to fit one with LED GU10 lamp however the danger is someone installing a 50watt gu10
The insulation will likely be solid celotex/kingspan . whoever insulates leaves a gap .
Once you ask of the building inspector the problem will not be yours,it seems to be a wise sparky who will ask the question but I have always just gone ahead and cut
What about making separate compartments,I wonder if that is a solution for a long discussed problem ?
Flat roofs, celotex and downlights...
Octopus,
johnduffell,
