Discuss flex for fire rated downlights? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
n180
I'm a bit confused about using the bit of white heat resistant flex for downlights. Do we really need it on fire rated downlights? Isn't it just an extra unnessasary connection?
Why not take the 1.5 standard T&E straight from the Hager (or similar) junction box to light? I'm still trying to understand the reasoning for the flex on fire rated downlights. What regs are we not meeting if we don't use the flex?
What flex are you talking about? Is this a flex fitted by the manufacturer or a flex you are fitting?
The downlights I use have a flex pre-fitted with a plug and socket similar to a click flow. You just connect T&E, flex, flexshield etc into the socket.
What brands that Dave?
Reply to flex for fire rated downlights? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi all, Got an antique light fitting that for some reason she wants putting up (can't say I love it haha) however it didn't come with any...
Hi all So had some issues lately related to high current fittings .. dp switches mostly. A number of electric boilers of various ratings .. from...
Hi all, about to do a condition report on a grade 2 listed 4 bedroom property, the owner is moving and wants to rent it out. The consumer unit is...
6K
Hi all We've had some works done in our kitchen which has involved fitting a new cooker circuit, installing some downlights to replace ceiling...
