Discuss Fuse Blowing on small motor in the UK Electrical Forum area at ElectriciansForums.net
have been asked us to look at installing a different fuse as the 13A plug top keeps blowing when they try to start the Motor, its a very small bench compressor.
He seems to think it requires a fuse to allow the inrush of current, but the plate of the motor states its only 1500W so should this be blowing a 13A fuse on start up?
I cant see why it cant be hard wired in to a circuit with a 10A type C MCB instead?
Was it supplied with a plug top on it?
The starting current would exceed 13A.
I don't know what it is for single phase motors - I rarely deal with them - but for a three phase machine it would be typically be six times full load current or greater. We are given power (1500W) but not power factor or efficiency. So even running current could be close to 10A. Maybe the OP can shed some light on that.
In short, it doesn't surprise me that a 13A fuse blows.
That data plate looks like the plate from the compressor unit, not the plate from the motor.
I read that as being a compressor which requires a motor which can deliver 1.5KW of mechanical power.
Have a look at the data plate on the motor and see what that has to say.
The rating plate says 50Hz, must be referring to the motor rating.
The plate also gives compressor data.
I would not say that it is off a compressor, in fact I can almost be sure it is not a compressor.
Why are you all trying to apply BS7671 theories to machinery which is not covered by BS7671?
Again.
Infinity, your bench compressor will comfortably/safely run off a 10A Type C circuit breaker.
If it 'morphs' into a vacuum pump it will still be OK.
God help us.
Reply to Fuse Blowing on small motor in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking for some guidance from more experienced hands. Have a friend who just bought a 2.2kw air compressor which is obviously blowing...
4K
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Hi First time with this kind of a job for me. I have a scenario where i am planning to install about 50m 25mm TPN from a TNCS supply to supply a...
6K
Greetings everyone. My first post here, having read a similar thread, I understand that following the manufacturers guidance is all important...
8K
How do you size the MCB, wire and protection for a motor in the UK/Europe? How is it typically done...
7K
