When doing a condition report what's the best way to find out fuse types , bs numbers an type of main fuse is being used if its an old installation an your not sure ?? An advice would be much aprciatated :stupid:
You can't - It is a bona fide limitation. Even if you put what it says on the carrier with regards to size (i.e. 100A) you are lying, better to put LIM
