Discuss Fused connection unit in a toilet block in the UK Electrical Forum area at ElectriciansForums.net
Stuy
Hi guys just wondering if someone can help me out here. I've been asked to install a metal hand dryer in a toilet block but the fused connection unit for it will fall within touching distance of the sinks.I've had a look at the regs but I'm still a bit unsure.Will the FCU need to go above the ceiling or will it be ok to go beside the hand dryer as long as the circuit is protected by an RCBO.Thanks
Hand basins don't usually warrant classification as a special zone so common sense would be the order of the day.
best thing for a toilet block is a plumber. about all they're fit for.
Fitted bloody hundreds of handriers in toilet blocks in schools , offices , pubs clubs. If I was installing new circuit would as others have said use common sense and fit fcu a reasonable distance from basins but have seen them fitted above and directly next to basins.
As others have already said, toilets without shower/bath is not a special location.
The equipment installed is to be suitable for the environment, general rules apply, on a side note not actually a reg in BS7671 but in the electricians guide to the building regs (I think) suggests minimum 300mm away from the edge of the sink.
What makes you think there would be a reg for the spur to be mounted where you suggested?
Reply to Fused connection unit in a toilet block in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
  • Locked
5K
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
