Can I put a fused socket in the bathroom then come of that from my double socket what size fuse would you suggestThe best circuit to come off is a lighting
But how ever if a double socket is to hand fuse down to that.
deletedCan I put a fused socket in the bathroom then come of that from my double socket what size fuse would you suggest
What's the best way to come off an existing lightdeleted
It would need investigation to find out how your existing light is wired. If there is a permanent live, neutral and earth at the ceiling fitting, then fairly straightforward to extend power to your new mirror position.What's the best way to come off an existing light
jump.What's the best way to come off an existing light
